Question about Empire ECS BF-30 Infra-Red Wall Mounted Panel Heater
Smell of gas while burning
We have the Empire ECS BF-30 Ventless Heater.  There are no leaks or smells when the unit is off, however, when the unit is on and burning, the gas smell is prevalent.  The smell since we first installed the unit has gotten stronger.
We are wondering if there is an adjustment to reduce the smell of gas (as we understand there will always be a slight smell).
We reside near Brighton, Michigan and if this unit requires service, is there a recommended technician for us to call?
Thank you very much for your time and help...
  • 2,309 Answers
Incomplete combustion could be a major health and safety issue. Seek qualified help and do not use until then.
Posted on May 01, 2017
  • 67 Answers
SOURCE: Empire BF-30-1 Main Burner problem
flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Posted on Jul 15, 2008
SOURCE: natural gas heater
I'm not a gas expert, however if I could offer an alternative possibility: I recently opened a gas heater to find a child (I assume) had inserted a CD and a pen into it. If the soot is more than a short term problem this is obviously not the cause but it may help some people.
Posted on Nov 24, 2008
  • 3182 Answers
SOURCE: Empire GWT-50 creating soot and sometimes flashs when starting
if it giving off soot then it is wrong it sounds like the air mixture is wrong and the flames are light back to the injector that would be the woosh , no heat er should give off soot if combustion is correct
Posted on Jan 10, 2009
  • 3182 Answers
SOURCE: 18000btu ventless empire heater lights and burns
Hi clean out tiles with air line clean pilot / if still goes out check thermocouple
Posted on Feb 12, 2010
  • 3182 Answers
SOURCE: I have a Empire SR 18 ventless LP heater and when
HI first check for a gas leak at pilot , check pilot injector sounds like the pilot injector is too big for some reason over pressure is also a factor
Posted on Feb 16, 2010
CO2 and flame "dancing"
This normally is caused by low gas pressure, or some blockage in the burners. Do not run this heater until it is fixed.
Jan 10, 2014 | Empire Comfort Systems Empire RH50C Closed...
Gas heater flame
How do I turn down the pilot light to high gives off smell
Jan 13, 2012 | Empire ECS HearthRite HR18MN Heater
It still has a burn off smell it won't come on at 2 and 3 when it goes off it make a sqealing sound sometimes
As far as the smell is concerned ... If you initially burned it on high for a minimum of 45 minutes, the smell should have dissipated. If however, you have recently painted prior to or just after it's installation, it's probably picking up the new paint odor and making it worse. Rug or floor cleaning products will do the same thing. As far as the squeeling noise is concerned, that could be caused by a low pressure problem from your LP tank regulator. If it occurs when the outside temp is well below freezing, more than likely the tank regulator is partially frozen. Soak a bath towel in hot water, ring it out and place it around the tank regulator to thaw it out. Once the gas is flowing freely again, the squeeling noise should cease.
If none of the above remedies your problem, contact ECS Technical Support 800-851-3153
Jan 26, 2011 | Empire ECS HearthRite HB20T Heater
There is a smell that is like a CO2 leak. It is not a natural gas smell.
it if smells or is burning yellow turn it off and have it serviced asap
Nov 01, 2010 | Empire GWT-25 Wall Mounted Panel Heater
I nee an owners/installation manual for an Empire BF-30
Try this link for the owner manual:
Oct 13, 2010 | Empire ECS BF-30 Infra-Red Wall Mounted...
Empire uf-30-1 can you use natural gas in unit buy just changing the burner orifice size
NO! You have to change the pressure spring it the gas valve and the pilot orifice also.SET it @ 3.5WC.
Sep 15, 2010 | Empire BF-10 Mid-Size Heater
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Charmglow Ventless Wall heater stinks - Literally!
some suggestions that may help: a sulfer type smell is the additive in the natural gas, kind of like eggs. if this is your smell, you have a gas leak. if any other propellents like hair spray, furniture polish, air fresheners are nearby, the vapors are burned by the stove and you can smell those, as well as a fine white powder building up on the stove. if a paint smell, then check to see if the back wall of the stove paint is burning away. if so, you can speed the process with a small hand held torch used for plumbing. when the paint is gone, the smell is gone. good luck.
Dec 30, 2008 | Heating & Cooling
Empire ECS BF-30 Infra-Red Wall Mounted Panel Heater Logo
109 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
