Question about Cameras
Iv got a dennard 5050 dome controled with a sprite kbs3 keybored,was workin fine but now i av no pan-tilt,with a message on the moniter saying..(MOT..bad endstop distance) HELP!!
  • 6 more comments
  • shiresstevey Nov 20, 2008
    i have done a shut down if thats what you mean.
    im sorry people im not tecnicaly minded,the zoom works ok and the keyboard seems fine,iv shut down about 3 times,once over night but this asnt helped.
    theres no soft wear
    it started wiv the tilt getting smaller and smaller and then spun round and wudnt move again,iv ad it up bout 2 weeks and al was ok,
    that sounds k,but i dont no if thats possible
    iv done that and no change,sorry
    links didnt work for reseting keyboard, is my problem definatly keyboard related and not the camera?
    its a dennard 5050 dome
  • 4,472 Answers
It sounds to me like the tilt is defective in the unit itself. I would have it replaced/serviced. If you still need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Nov 20, 2008
    Sergeant:
    Champion:
  • 435 Answers
Try moving the camera and see if you still get the "Bad end distance" error.
Its the error, when the camera cannot tilt/ move beyond its limit.
If nothing works, Go for their customer support
http://www.dedicatedmicros.com/uk/support_contact.php
  • Cameras Master
  • 19,396 Answers
Check the cables and the connections.
If you are connecting through the 485-bus ports it can be a lose connector or a bad cable that have gone deteriorating in time, this would explain the tilt getting smaller and smaller.
If it is connected on DM/JBX check junction boxes and cable.
The tilt can also be jammed, you can try moving the camera gently, be careful it is quite easy to damage themif you push them too much.
I quote from manual:
"The remote keyboard is supplied with a 2m length of 485-bus cable; this is used to
connect the keyboard to either of the 485-bus ports on the D4, Digital Sprite 2, or BX2
unit.
The remote keyboard can also be connected over longer distances, up to 1500m
(4900ft), using 2 junction boxes (DM/JBX), a 12v 1A PSU, and the required length of
twisted pair cable, for example CAT5."
If you still cannot solve it call the installation technician, the tilt may be faulty.
  • 685 Answers
Http://www.bloudex.com/images/catalogue/197.pdf here you go this should help
  • 8 more comments
  • Juanita Vega
    Juanita Vega Nov 20, 2008
    Recalibrating the joystick
    If the telemetry camera drifts when it is not being used, the joystick may have to be recalibrated.
    To do this:
    1. Un-plug the keyboard from the system.
    2. Press and hold the [ (star) button.
    3. The keyboard will beep. Rotate the joystick 360° until the camera key LEDs stop
    flashing.
    4. Twist the joystick fully left and right until the cameras key LEDs stop flashing.
    5. The joystick is now calibrated, press the [ (star) button again to access the unit.
  • Juanita Vega
    if this doesn't work let me know and i can get you to the site to reinstall the keyboard
  • Juanita Vega
    yes it is i found it in there site try it and let me know what happens thatk you for using fixya
  • Juanita Vega
  • Juanita Vega
    Downloads:
    UPGRADE_PCAPPS.zip - PC Application (1.9.0) - (58.8MB)
    SD16_4_2_13_95.pdf - Release History
    UPGRADE_WEB.zip - Webpage Upgrade 2.0 (1.81) - (712KB)
    UPGRADE_C2DM.zip - Codec Upgrade 1.5 (016) - (904KB)
    NVD0UPGRADE_m3sp.zip - Main Application 4.2 (13.95) - (2.6MB)
    SD_Network_Upgrade_Instructions.pdf - Upgrade Instructions for Network Connection
    SD_USB_Upgrade_Instructions.pdf - Upgrade Instructions for USB Pen Drive
  • Juanita Vega
    Software Downloads here is the download you need to reload the keyboard if you want to try that
  • Juanita Vega
    i hope this helps you
  • Juanita Vega
    did you try what i sent you? hopefully it helped you.let me know
  • Juanita Vega
    we can try reinstalling the camera what type is it?
  • Juanita Vega
    http://www.cctvsoftware.com/conequip.htm try this site
  • Cameras Master
  • 4,806 Answers
Try to re-install the keyboard drivers
regards
  • Lee Hodgson
    Lee Hodgson Nov 20, 2008
    shutting down will not resolve the problem, if you got a driver disk with the keyboard run the disk and install the driver and/or software
    see if this helps
    regards
  • Lee Hodgson
    the software or firmware on the camera is somehow corrupt or damaged, can you reset the camera back to default or factory settinngs?
  • 790 Answers
Hello!!!
Do a hard reset and give a try!!!
How do i adjust the zoom control on the logitech C270 so that i can use the pan and tilt functions?
Do any of you have Follow my face option enabled while trying to use the Pan and Tilt feature? If so, please disable it and try using the Pan and Tilt feature again.
Aug 23, 2014 | Logitech C270 Web Cam
CAN YOU PLIZ HELP ME FIX MY TV
Press the AV button on the remote control. If it do not help you, make it a hard reset.
May 28, 2013 | Universal 40-42 Inch Flat Screen Panel...
Pan and tilt controls
I had this problem on the Logitech 9000 and found it was due to the "Follow my face" option being checked. As soon as I unchecked it the zoom, pan and tilt controls worked.
Jul 01, 2012 | Computers & Internet
Welbilt abm-100-3 is it a 1-lb maker or 1 1/2 lb maker?
Welbilt Bread Machine Pan ABM100 2 LB Pan
Round 2 Lb Pan
Everyday Sale Price : 15% Off Sale!
$18.99 $16.14
This is the pan for the Glass Dome Wlbuit Bread Machine
Should fit..
Welbilt
ABM100, ABM100-1, ABM100-2, ABM100-3, ABM100-4, ABM150R
DAK
FAB100 , FAB100-1 , FAB100-2 , FAB100-3 , FAB100-4 , FAB2000 , FAB2000-IV
Turbo Baker I, Turbo Baker II , Turbo Baker III , Turbo Baker IV, Turbo Baker V
Jul 08, 2009 | Kenmore KTR2300 Bread Maker
I have an Acer 5100. Freq. I have an error message. Reinstall
the eData security mangement is for security such as parental controls.u must have deleted it ,or possibly corrupeted the file you can find the neccesary downloads at acer pan am america,,steve
Feb 10, 2009 | Acer Aspire 5050-3242 Notebook
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Cameras Logo
82 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
