Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa m200 mp3 player
It dosent work and when it do its keep restarting by it self and my pc cant read it what to do ??
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
I have a sanddisk m230 mb mp3 player and i need a instrctions manual.What should i do please advise me
Manual, in pdf format, for the m200 series is on this site:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
pdf files can be read when Adobe Reader is installed
when not having installed, get the reader here;
http://get.adobe.com/reader/
Sep 26, 2010 | SanDisk Sansa m230 MP3 Player
I need a manual on how to work the buttons on my SanDisk Sansa mp3 player. I cant even get it in english. please help.
Sansa manuals can be found on sandisk.com:
  1. Enter the link sandisk.com in internet explorer
  2. Select Support
  3. Enter manual in the [Search All Answers] bar. For the m250 enter manual m200 in the [Search All Answers] bar.
  4. Select your manual from the list
How to get the the player in english:
  1. For the m250, enter m200 english in the [Search All Answers] bar
  2. Select the link "Navigating to the Language Menu" and follow the steps
I'd appreciate your vote if this was helpful.
Just post a comment, when needing more help.
Jan 13, 2010 | SanDisk Sansa m250 MP3 Player
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m200 mp3 player problem...
check this out....http://www.anythingbutipod.com/forum/showthread.php?t=20366
Jun 21, 2009 | SanDisk Sansa m200 (2 GB) MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240
You do not need anything from the CD, it only has Windows Media Player 10.
All you nee is a PC with XP / SP 2 and Windows Media Player 10 or higher. No drivers are necessary.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Sansa m200
If the device is connected to the computer, it will be listed under My Computer. If it is not listed, you can check the Device Manager to see if any errors are listed. If there are, right click on them and select "uninstall". Disconnect the device and re-connect it to the PC. You can add to this question if you need more assistance. Best of Luck.
Sep 27, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Problem
Have you tried removing the battery? Or maybe your battery is low. As well, if your mp3 player isn't turned on when you plug it in, that seems to affect if the computer recognizes it.
Nov 05, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
