Question about Plumbing
Flexy pipe on m/ tap in kitchen
15mm pipe from copper to taps and tix taps to sink
    Champion:
  • 203 Answers
Whats the problem?
Posted on Nov 22, 2008
Why has cold water taps running slow upstairs and not downstairs
Is the piping going up stairs copper or galvanized pipes? Galvanized pipes will plug up over time so they have no pressure. Do your taps have have screens on them where they run into your sink. They could be plugged and need to be taken off and cleaned out. The faucets them selves could be partly plugged at the rubber gaskets where they turn inside i suspect if you have older taps upstairs you may have to replace them..
Dec 17, 2017 | Water Garden
How do I set up the plumbing to convert a single bathroom sink to a double sink?
hot and cold supply is easy. You need to solder in a copper T-piece, and to that add a short length of copper pipe with an isolation valve and then connect that to a flexible braided pipe to the faucet.
Waste water not quite so easy. Have both P-traps fall to a cross pipe that goes to your existing waste.
A plumber could do the job in an hour and a half.
Oct 29, 2015 | Plumbing
Can I bypass heater core on my mercedes 1995 c280
Yes quite easly ,look for the two rubber pipes going to the firewall and then disconnect them and join them together with a small length of 15mm copper pipe .
Jul 11, 2015 | Cars & Trucks
Diy plumbing
most likely that it is a old drain pipe as some plumbers used copper for that purpose. if it is a drain all u have to do is cap it. if it turns out to be a vent pipe u can install a end of the line vent cap. I cant remember what it is called but your supply store will know. just tell them u want to install a vent under the sink not through the roof.
Jun 04, 2014 | Plumbing
Car is getting hot quick and coolant is coming fro under dash
heater matrix has gone ,its a dash out job to repair so join the heater pipes together with a bit of 15mm copper pipe and then trade it in quick and let someone else have the problem
Apr 29, 2012 | Cars & Trucks
What size copper pipe is needed to connect my gas range to the gas supply
probably 15mm but this depends on output of appliance, distance from gas meter and wether other appliance are part of the pipe run.
Oct 17, 2011 | Kitchen Ranges
Inlet Valve leaking
I would try PLUMBER'S GOOP (hardware store) on the copper pipe. Remove it and put a liberal amount of goop on the end about a quarter inch back from the tip -- insert and smooth the goop around the connection -- let it cure for 24 hours -- turn water back on.
Charlie
Aug 22, 2009 | Home
Clarify application of straight ball valve 1/4 turn
The ballvalve is normally a compression type fitting and so would not normally require soldering, however you could use a threaded adaptor soldered to the copper supply line and then thread a 1/2" ball valve to that then reduce down to the correct thread to meet the tails from your new tap. Or alternativeley you can insert the valve in the supply line, and extend the pipe to nearer the sink to enable easier connection of the tap.
Nick
Mar 28, 2009 | Plumbing
Fitting monobloc kitchen diagram on pipe fittings
The tap should have 2 pipes about 6-10 inches long and almost the thickness of a maker pen {10mm or 15mm]
U will need either a 10-15 connection or a 15-15 connection either straight or elbowed according to routing need to main pipes [& these should also be 15mm
connections are fixed either with solder or have nuts on each end to tighten [compression] or are just push-on ["Speedfit"]
Ger back if u need more
Mar 23, 2009 | Plumbing
Cold water only very slowly trickles into the washer. Hot water works fine. Cold water has very good pressure and volume at all other sources in the house. The cold water hose at back of washer is clean...
there can be 3 reasons for this I will tell u the easiest way to test this first
Problem1)turn the water off at the blue tap fitting that is proberbly under your sink take the blue pipe off at the washer end and place it into the sink turn the blue tap back on if the water comes out quick then the problem is more then likely your cold water solenoid that is either slightly blocked were it fits to the washer,But if it doesnt come out quick then the other 2 problems are as follows.
Problem2)the blue tap that u turn the cold water on to the blue pipe undue the little screw in the middle of the tap and pull the blue fitting off now with a pair of pliers turn the square metal fitting that was under the blue fitting making sure that the end of the pipe is in the sink if it comes out quick then that is the problem the blue tap fitting is rounded off when ot should be square turn the water of and replace the pipe and turn the water back on the cold water should be better now.
Problem3)the blue tap that u turn the cold water pipe of at the copper pipe is blocked or it has a broken shut off valve inside it this will need replacing these are the only problems that it could be let me know if this is any help to u peter
Jun 09, 2008 | Whirlpool Washing Machines
Plumbing Logo
121 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
