No water coming into washer, but washer starts agitating at start
I have never had a problem with this washing machine ever, but this morning when I turned it on to start it just started agitating without any water. I moved the dial to rinse only, same thing. I moved the dial to spin, nothing. I moved the dial to off and turned it on for a few minutes. I moved it back to start a cycle and it just started agitating with no water again.
  • cegroves Nov 23, 2008
    It ended up being the timer. Thanks...
  • 833 Answers
Your water level switch is defective.  It is generally located below the tub.  It is jammed closed and the machine thinks it has water in it when it does not.
Posted on Nov 20, 2008
  • 23 Answers
SOURCE: Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Posted on Nov 30, 2007
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 10 Answers
SOURCE: agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
Posted on Jun 14, 2009
I loaded the washer and turned it on, no water was coming out and the machine went into agitate. The machine does not allow water in, but starts agitating immediately. What's wrong? Thank you.
It sounds like whatever the machine uses to sense the water level is stuck. This would make the machine think it is already full of water. I do not know enough about your machine to help any further. Maybe if you bounce each corner of the machine a few times you can free it up.
Jul 29, 2016 | Washing Machines
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Ge 9 min light flashing
I broke down and had a technician come and fix it for me. It ended up being a loose wire in the panel.
Apr 22, 2013 | GE WBSE3120B Top Load Washer
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing machine
check the water pressure switch and the hose connected to it for an obstruction
if the machine is aggatating it can not allow water to come into the machine cause it thinks it is at the water height that the pressure switch is set at or the tube was some gunk in it that is making the switch stay closed
remove the hose from the pressure switch it is clear and blow through it if it blows freely then the pressure switch is bad and replace it
if not blowing free blow hard to remove obstruction
Jun 13, 2008 | Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
