Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice forming in freezer refrigerator not getting cold
Ice actually looks like frost or snow. Refregerator only 3 or 4 months old. Whirlpool side by side
  • 370 Answers
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Posted on Nov 20, 2008
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Frost and ice is forming in the freezer of my ED5FHEXNQ00 whirlpool side by side.Refridgerator is not very cold.I have defrosted 3 times now.Refridgerator is still too warm,and ice forms again in about 3...
You have 1 of 3 things going on. Either the defrost timer has gone bad, the defrost terminator is bad or the defrost heater is bad. The problem is one of these 3 things and even if you replace all 3 items the repair is still inexpensive to do.
Jun 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
All of a sudden, my refrigerator doesn't keep anything cold like it used to but the freezer still works. We have cleaned underneath but it still doesn't keep anything cold. What could be the problem?
Look for signs of frost on the back side. You probably have a defrost problem of it could be a drain problem.
Your ice box cold air originates in the freezer. A fan pushes down the cold air into the fresh food section. If their are too many items in the freezer the air can be blocked to the fresh food section. If the drain stops up sometimes a puddle forms a slab of ice between the freezer and the bottom. I ave an apartment maintenence man's guide to these ice box's for you HERE. It feature 4 differnt styles of whirlpool ice box's in your size.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 25, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
307 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
