Question about Cyberhome CH-DVR1500 DVD Recorder
Cyberhome ch-dvr 1500
Last post my dvr appeared dead. has resurrected itself several times since. still crazy display, only works with remote, can play dvds, have not tried recording since first death, front audio doesn't work, dies temporarily if I have a power outage,sometimes will come back on if I relpug power. I think that's it...
  • Susan Getchell Nov 20, 2008
    hello, I am confused. I have received emails from several "experts" but can only access ekse.
    I have of course tried to contact the dealer but cyberhome (as you must know if you are indeed an expert) is out of business. I do not consider advice like take it to a repair shop expert advice either.
    I'm stunned, I feel I've been ripped off. That kind of advice should have been free.
  • 4,806 Answers
Try and reset the machine back to factory settings or update the BIOS through the Cyberhome Update site here: http://www.dv-rec.de/download/firmware/ch/index.shtml
hope this helps
regards
Posted on Nov 20, 2008
  • Cyberhome Master
  • 13,433 Answers
Its best that you contact your dealer or the maker of the dvd recorder to get it repaired.
    Genius:
  • 1,550 Answers
There is some fault with your recorder . You have small internal defects .
You need to contact service center to get it repaired .
  • SAM ANDERSON Nov 20, 2008
    There is some fault with your recorder . You have some internal defects .
Cyberhome 1200 dvr
First the Dvr 1200 has hard ware failure in it the tray eject unit and the display is failed ........................................it can fix in local service center.............................
Second your New DVR 1600 check the format of the dvd is it compactiable with format of the player and if face the same problem get it replaced as this is new player manual opening could lead no warranty on the player , it better to get it replaced ..
May 30, 2008 | Cyberhome DVR 1600 DVD Recorder
Need Manual for CyberHome CH-DVR 1500
http://www.usersmanualguide.com/
go here
Rod
Apr 14, 2009 | Cyberhome CH-DVR1500 DVD Recorder
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Need remote codes
I have DirecTV and I have the same remote and I read somewhere you can use the codes for Sampo. I found the codes in the DirecTV remote's manual. The first one I used worked. Hope this helps!
Dec 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Unit died
push the power and hold it down for a minute....
Sep 21, 2008 | Cyberhome CH-DVR1500 DVD Recorder
Universal remote control
I have CyberHome DVD Player CH-DVD-300. I want to download the user manual. Can anybody help? Thanks.
Feb 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
Need remote codes
I have a CyberHome CH-DVD-300 unit with a Dishnet remote. The remote code that worked for me is 724.
Sep 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Looking for owners manual
Here are the manuals: User Manual ftp://209.237.61.78/cyberhome/1500/manual/1500E.PDF Quick Setup Guide (1) ftp://209.237.61.78/cyberhome/1500/manual/1500_Quick_Guide_1.PDF Quick Setup Guide (2) ftp://209.237.61.78/cyberhome/1500/manual/1500_Quick_Guide_2.PDF More info check this page: http://download.cyberhome-dvd-help.com/usa-stuff/ch1500/ch1500.htm Good Luck
Jun 04, 2007 | Cyberhome DVD Recorder - DVR1600
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
350 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
