Question about LG Studioworks 563N 15" CRT Monitor
Display adapter my display adapter driver sis 300/305/630/450/730 canot work at 1024 by 768 pixels screen resolution
  • 348 Answers
Yes it will not support bacause there is an internal display card you are just looking its disadvantage so you must attatch the AGP card then it will support all video graphics
Posted on Nov 20, 2008
  • pravin bhavsar
    pravin bhavsar Nov 20, 2008
    purchase new AGP card
My monitor s19a100n displays slowly when the command is already givento to Pc. What might be the solution for this problem?
That your PC is busy, the display has an offset of somewhere aroung 5 ms for your display. You won't even see more than just a slight blur even in quick movements. Anything above that orgiginates in the computer.
You might have set a bigger resolution for a new monitor, thus increasing the workload for your graphics adapter.
Example:
For a 1024 x 768 resolution, the PC must compute 786,432 pixels. Your display (1366 x 768 pixels) has about 30% more pixels to compute. (for an HD display that number increases to two and a half times as many)
Test:
(presuming, you run windows) start the task manager (right klick the status bar, usually on the bottom of the screen), select task manager and then the tab "performance", where you can see how busy your CPU is and whatamount of ram / swap is used.
Resolution:
Reduce your resolution, get a better graphics adapter, upgrade CPU / ram, decrease background programmes.
Nov 27, 2014 | Computers & Internet
CANOT GET FULL SCREEN ON MY LAPTOP
Makesure you have installed latest drivers.. Or try to change resolution from display property
Oct 10, 2012 | Microsoft Windows Vista Ultimate Edition
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
Yesterdy i was working on an optical drive issue with a comp, got it done by removing an extra drive from this computer...but...the video on this computr is not wrkong now...what issue? what is the...
Hi
What is the Resolution
Refers to the sharpness and clarity of an image. The term is most often used to describe monitors, printers, and bit-mapped graphic images. In the case of dot-matrix and laser printers, the resolution indicates the number of dots per inch. For example, a 300-dpi (dots per inch) printer is one that is capable of printing 300 distinct dots in a line 1 inch long. This means it can print 90,000 dots per square inch.
For graphics monitors, the screen resolution signifies the number of dots (pixels) on the entire screen. For example, a 640-by-480 pixel screen is capable of displaying 640 distinct dots on each of 480 lines, or about 300,000 pixels. This translates into different dpi measurements depending on the size of the screen. For example, a 15-inch VGA monitor (640x480) displays about 50 dots per inch.
Printers, monitors, scanners, and other I/O devices are often classified as high resolution, medium resolution, or low resolution. The actual resolution ranges for each of these grades is constantly shifting as the technology improves.
Solution :
1.
If you not get the proper video image in your screen that mean you have remove the driver of video, for installation the driver, put the Driver -CD in rom, and start the setup is simple set you get the driver.after installing the driver restart your PC
2.
If you change any display setting then also you get the occur.for set the resolution go to the control panel and select the Display and go to setting tab set the ' Screen resolution" as before.
3.
If you still not get the display then open you PC and remove the RAM and put again,and try again.
God Luck
Sep 15, 2011 | Asrock P4I45GV R5 Motherboard
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
LCD not being detected
Restart computer -> Keep tapping on F8 key till safe mode option appears-> login using safe mode -> when login complete -> rightclick on my computer -> properties-> hardware tab -> Device Manager -> click on Sub-option "Display Adapters"-> Right click the adapter inside -> properties -> driver tab -> rollback drivers.
Follow instructions and restart and choose normal windows if asked.
If not successful, goto start -> all programs -> Accessories -> System tools, -> system resore -> choose restore to a previous... -> choose a date before the date you updated drivers. dont go 3-4 month, you might loose data. choose a closer date to the date you found the issue. follow the instructions.
restarts automatically and recovery screen comes. dont worry this is normal. when done, restart the system and see if resolution is alright.
get back to us with what has happened, we will support you further.
thanks, have a nice day....
Sep 16, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
Toshiba satellite 2410 note book
i don't get the meaning of your description, but you can try to adjust the resolution of the screen by click the space of the desktop, choose "attribute", then choose "setting",change the "screnn resolution" to 1024x768 pixel.if it does not work, reinstall the windows opration system.
Toshib stellite 2410 battery
Apr 24, 2008 | Toshiba Satellite 2410-S203 Notebook
LG Studioworks 563N 15" CRT Monitor Logo
166 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
