Question about Karcher 2500 PSI Pressure Washer
Karcher 2400 Power Washer upload valve
Lubed and reinstalled upload valve with spring, all O rings and split ring. It leaks. Did I loose something or is there a specific way to reinstall. Everything is tight.
Is there a diagram available?
    Sergeant:
    Champion:
  • 239 Answers
The manifold has a small crack on it
Posted on Dec 28, 2008
  • Alvaro Domingues
    Alvaro Domingues Jan 07, 2009
    did i help?please rate!!
KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hello there.
If the washer is loosing pressure then it needs to be looked at under warranty, im not sure where the fault would be, but another expert may well know.
If you don't get any suggestions then i would take it back and ask for a replacement or repair.
Hope this helps.
May 09, 2008 | Karcher 2500 PSI Pressure Washer
REMOVE PUMP
Look for a black plastic cover with a silver snap on top; pry off the silver snap and lift off the plastic cover; next remove the two screws on the top plate then pull out the piston inside - if unable to lift out, start unit and watch it pop out - coat piston with lithium grease and reinstall.
The sticking pressure relief valve is somewhat common with the Karcher 2400HH series pressure washer, it is caused by hard water and lack of grease on the pressure relief valve. To remedy the problem, use silicone (plumbers) grease to lube the o-rings on the unloader valve part# 4591040 (karcher calls it a spill valve on the parts list) You can click on the link below for more help. A helpful note, if you store your pressure washer for long periods of time, than you should draw anti-freeze into the pump for storage... make a short 2' garden hose and connect it to the inlet of the pump, with a funnel stuffed into the end, poor anti-freeze into the hose and start the engine, this will draw the solution into the pump and protect it from corrosion and keep all internal parts lubricated (plus keep the pump from freezing).
Here is a link that might be useful: Pictures of the Karcher 2400HH Spill Valve
Dec 15, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
No pressure. Have cleaned inflow filter, checked water supply and cleaned and lubed the uploader valve.
if there is water comming out of the back of the pump then your piston seals need replaced , if the lace vibrates then one or more pump valves are blocked ) theres 6 in total /in pairs ) , try running the machine with no hose/lance connected as the lance nozzle often blocks up /malfunctions
hope this helps , if it does please vote
Nov 13, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
Motor starts and stops
Diagram here
It could be the Overpressure valve is leaking #20
It could be one of the small valves is not sealing #14 and #15
The soap valve could be not sealing #7
I have also seen micro cracks in the cylinder head #8
Good Luck
Jul 19, 2009 | Karcher K2.26 Electric Power Washer
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
How do you clean the unloader valve on a power washer pump?
The unloader valve usually is replaced. I dont know if you can get o-rings for it. But if you want to take it apart, there will be a crown or cap style nut just below the spring. Unscrew it completely and you will be able to remove the spool. There is just a series of o-rings on it.
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
392 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
