Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Water look at the bottom of screen
I got this tv from a buddy and what happens is that when the tv is on it has this blue like maybe green water like screen at the bottom and if we watch the tv long enough it will go towards the middle of the screen straight up..... can anybody help me its a great tv for playstation...but would like to watch tv too
    Genius:
  • 1,694 Answers
Probable bad Optical block Assy. part # A-1606-008-A
at cost.....750.00 + 600.00 core............................T.
Posted on Dec 26, 2007
SOURCE:
The colors of the tv are fine except for the blue, things that should be blue are green
The board that called the T-Con board it is could be dead.This T-Con board control the out put tv signal to the tv LCD screen panel.This T-Con board sit at the bottom in the middle bottom of the tv LCD screen panel. Take the connection out of the T-Con board .Tries clean the connection of the board with some rubbing alcohol,might fixed the problems,if not.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-Con board for the replacement.
Jun 01, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Broke
Sounds like maybe the convergence chips are shot
Oct 06, 2007 | Zenith IQB56W10 56" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
