Question about Magicard Tango 2 Printer
MagiCard Tango 2 Badge Printer
I'm getting a Venitian Blind Effect on the printed badge. I've corrected all the setting to read Tango in the printer drivers. I've reinstalled the lastest printer drivers. Haven't been able to correct the problem. I've tried both USB and Serial connections.
Any suggestions
please email me at sam.hirsch@ngc.com
  • samirsabri Jan 06, 2009
    My Tango2 printer is not communicating with my computer.....
    I Used to use it properly until one week ago, then I started to get the “unrecognized USB device message on my laptop", I know it seems to be very clear that I have a problem with my printer's USB interface..... Any suggestions
    Thank you
    SDS
    Scholar:
  • 71 Answers
Hi There,
This is very a very common problem!
Fortunately, it's really easy to fix too;
Go to your 'Printers & Faxes' folder. Right-click on 'Magicard Printer Series'.
Select 'Properties'. Click on the 'Device Settings' tab.
Select the correct printer model in the drop-down list (Tango 2);
I suspect you currently have 'Tango' selected.
I hope this helps.
With Best Regards,
MC.
Posted on Nov 23, 2008
Hello, We have a problem with our EVOLIS PEBBLE
reload the ribbon make sure you load correctly and set the correct type of ribbon on the driver make this and reply to me
Aug 24, 2011 | Evolis Pebble Color Card Printer
Hello, I am using the Magicard Tango 2e. I
Hi Mahom -
It sounds like your printing software has sent the print-job to the Windows print-queue as a single job. Because it didn't complete originally, and then you reset the printer (power-off), it has now lost track of where it was and will only start at the beginning of the job again. Best thing to do is unplug the printer again; cancel any pending jobs in the Windows print queue for the Tango printer; then re-print job EXCEPT for the cards already printed.
Nov 13, 2017 | Magicard Tango 2 Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
Magicard rio 2e, the printer needs to print the access codes on the otherside
The Rio 2E is a single side printer to print on both sides of the card you need a Tango 2E Printer.
Aug 05, 2009 | Magicard Rio ID 2 Card Printer
My Magicard tango 2 is Locked
Hi There,
The printer will say 'Locked' if someone has removed a custom HoloKote key from the slot in the front of the printer. Have you ever had a custom key fitted to this slot?
First of all, make sure you have the very latest version of firmware installed in your printer. You can find this here;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
If after updating the firmware, the printer is still saying it is locked, download and install the Magicard Support Utility (available from the same site. Run the Support Utility and select the 'Query Printer' tab.
Then press the query button. You can then save the result of this query as a text file. You can paste this into your reply. This may give a hint as to what the problem is.
With Best Regards,
MC.
Apr 05, 2009 | Magicard Tango 2 Printer
Badge labels
do you user manual? its in there
you can navigate by selecting bypass try first,select label printing
machine and printer setting must be the same,
hope that help
Oct 06, 2008 | Minolta C350 Color Printer/Scanner/Copier
Printer issue...:(
Hi MaCaTa2,
It can be frustrating when things aren't going smoothly.
Sounds like you're wasting a lot of dye film and cards too!
What program are you printing the badges from?
You have a very 'paper' size with this type of printer.
If you select 'Magicard Printer Series' as the printer, you will then see a special paper size called 'CR80 Edge To Edge'. This is basically the size of a credit card. (2 1/8 x 3 3/8" (54 x 85.6mm). Check your font sizes are not too big. Any text printed on the back of the card is on page 2 of 2 (on the Tango model, a Rio would feed a second card).
Experiment with an application like MS Word, where you can clearly see the 'pages'.
Create a new word document, straight away go to 'File, Print', select 'Magicard Printer Series' from the printers list, then 'Close' (not 'Print'). Next, go to 'File', 'Page Setup', for the paper size choose 'CR80 Edge to Edge', set all the margins to '0' (this is a 'full bleed' printer.
You will now see a credit card size page to work on. If you fill this page (or insert a page break), you continue onto page 2 (the card back - only available on Tango).
I hope this helps.
Regards,
MC.
Jul 01, 2008 | Magicard Tango 2 Printer
Offline
Hi There,
I think this may be something Win 2K is doing.
However, rather than power cycling the printer, simply removing the USB connection then replacing it should be enough to 'wake it up' (and save on dye film).
Check the power saving settings for your USB Root Hub;(Hardware/Device Manager/USB Controllers/ USB Root Hub/Properties/Power Management). Make sure the 'Allow the computer to turn off this device to save power' option is NOT ticked.
Check also under 'Settings' / 'Printers', right-click on 'Magicard Printer Series', you should NOT see either 'Resume Printing' (printer is paused), or, 'Use Printer Online' (printer is offline).
Also, make sure you have the latest drivers installed. The Rio 2 / Tango 2 driver V6.01 is compatible with the 'older' Rio / Tango printer (even the non 'NP' models). You can download this here;
Make sure though that you select 'update driver files' and NOT 'add a printer' when prompted (restart is required). Port name should be 'NUSB01' when you see the list of available ports.
I hope this helps.
Regards,
MC.
Mar 11, 2008 | Magicard Rio Card Printer
Mis-register
Hi There, 1. Make sure there is no dye film stuck to the print roller. This will cause card mis-registration (you will see feathered edges or a blurry effect. If there is dye film stuck to the print roller peel it off using adhesive tape or similar (the dye film will stick to the tape). You can move the print roller round with your finger quite easily. Then clean with a normal cleaning card. Afterwards check your print start and end position (you may be printing off the end of the card - also snaps the ribbon often!) 2. Make sure the other pinch rollers are really clean. 3. ** Check the warranty status first! *** Remove the right-hand side panel (2 screws on the side, 3 at the back). Check for free play on the card transport stepper motor pulley (there should be none!). Check the belt tension is not too loose (motor is adjustable - loosen 4 screws)). Hold the print roller with your left hand while trying to turn the large plastic pulley. You should feel no play. The grub screw on the pulley can sometimes come loose (1.5mm hex key required). Do NOT try to use a ball ended hex key. This only rounds off the grub screw socket. I hope the above helps! Regards, MC.
Oct 19, 2006 | Magicard Tango 2 Printer
Magicard Tango 2 Printer Logo
607 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
