Question about Whirlpool GS475LEKS Gas Kitchen Range
WHIRL POOL OVEN BURNER WILL NOT IGNITE
WHIRL POOL OVEN (SF376PEW)
WHEN KNOB IS TURNED THE BURNER WILL NOT FIRE UP. THE PORCELION COMPONET WILL NOT GET RED LIKE IT USED TO IT ONLY STAYS WHITE...
    President:
  • Whirlpool Master
  • 2,651 Answers
The porcelain always remains white its the glow bar toward the end that will glow, you will need to check for power leading the ignitor, if indedd you have 110v, there replace ignitor very common issue with gas ranges
Posted on Nov 23, 2008
I tried to use the oven part of the glem gas, the igniter fires it up but it turns off as soon as I remove pushing the knob
can you smell any gas when the knob is set ?
before you ignite
in none or only a small smell of gas
can only think the gas valve faulty on that knob or the
gas pressure to the burner is lower than it needs to be
this is an example its a glen gas double oven
Oct 17, 2016 | Kitchen Ranges
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
May 16, 2014 | Whirlpool Ovens
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Thermador over two left burners will not provide gas when knobs are turned. Also the oven will not light and the igniters on all burners will not spark. The electric is good to the appliance oven fan
You have multiple problems! First the single igniter that fires in all of the burners is either broken or disconnected electrically. Second, your gas lines or nozels at some of the burners are clogged. Check for cloggs by using a match as you light ONE BURNER AT A TIME...If they all light you only have the electronic igniter to troubleshoot...Have a repairman check it out for you if you don't feel confident with gas!
Dec 21, 2012 | Kitchen Ranges
Hello
There are a few things that you will need to check on these pool heaters if your unit is ignited, but your burners wont fire. First, and this probably seems obvious, make sure that the knob is set to the on position. Next, cycle the ignition sequence until the air is out of the gas line. If it will still not fire, replace the gas valve.
May 03, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Whirlpool GS475LEKS Gas Kitchen Range Logo
138 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
