Question about Nokia E71 Smartphone
GPS Weak or no reception
I always have a weak reception on my device.
How can i check if its a device problem or my location.
I have been told that i need to approve some certifications on the device. Is this issue related?
  • 2,794 Answers
Goto Nokia.com and see if there are any software upgrades for you phone. If it is needed, install Nokia PC Suite as well if there are any needed. Purchase a USB cable as well for your cell phone if you don't have one already.
Posted on Nov 20, 2008
  • 734 Answers
No its not related to certifications issue because if that is the issue your GPS device will not working at all.
  • futureloginn
    futureloginn Nov 20, 2008
    it’s a issue related to your location only
  • Nokia Master
  • 19,396 Answers
To check if its a device problem connect the GPS module to a different computer, phone, or PDA.
Check that all connections are fine and that there is no oxide on the connectors.
Why am I being told that my signal to my tv is weak and that must come to you for assistance.
Are you on cable or Arial If on Arial you may have to turn the head one way or the other to get the program to come in also weather conditions have a lot to do with this.Weather effects the cable reception as well. If the TV works most of the time but not other times it could be the weather. or a weak booster on your areal
Sep 22, 2014 | T-View Car Audio & Video
Weak wifi reception on my coby 4331 tablet
The solution for this problem depends on how you are using the device. It depends mainly on how thick your walls are and where you placed your wi-fi router. If you can't change the location of your router, I suggest you to get a new, more powerful one. A cheaper solution would be to move, if possible, the router. The thickness and number of walls between the device and the router decrease the signal's strength considerably. You could also install a repeater, though you'll need to place it where the signal is at medium strength, in order to boost it. The repeater should be of the same manufacturer of your router, as it will have 100% compatibility.
Mar 26, 2014 | Android Tablets & eReaders
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
No signal or satellis
The device has to find at least four GPS satellites to be able to calculate your location on the map.
If the GPS signal is weak or your device is only able to see three satellites or fewer, the location icon is shown in gray, the Driving View is shown in gray, or one of the following messages can be shown:
  • Waiting for a valid GPS signal
  • Poor GPS signal...
  • The GPS signal was lost x seconds ago
Keep in mind that even if your device is working correctly, it may take a couple of minutes for it to work out your location when you switch it on.
Sep 06, 2013 | Tomtom GPS
I was driving home today and our Nuvi1200 said it had a low battery. I plugged it in. Not 15 minutes later it just shut off, leaving me stranded in a city that I had no clue where I was. Not able to turn...
The connectors are alway a weak point on these devices, you need to check the lead is ok and that the power is on on your cigarette lighter socket. Also worth checking the fuse in it if not.
Murphys law is things will always fail at the worst possible time.
When you are home check that the device can be powered by your computer or a charger.
Then you will know if its the lead or device.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Garmin nuvi 1200 Car GPS Receiver
Roadmate 2000 has suddently started giving me crazy directions. If I followed them, the routes would take me 30 miles out of my way.
  • Check first the signal. Make sure the signal is not weak. Because if the signal is weak normally thats what will happen.
  • Reply to this solution if you have questions.
Jun 12, 2010 | Magellan RoadMate 2000 GPS Receiver
My tn30 the sattelite signal is to weak
I may be able to help you improver your Motonav TN30 satellite reception.
Satellite reception is one of the issues addressed in Motonav TN30 firmware updates.
These Fixya Tips describe how to download and install the firmware for your Motonav TN30:
Motonav TN30 Firmware Fix
Motonav TN30 Upgrade Manual
I hope that helps.
______________________________________
Motorola Motonav TN30 Manual Download
Apr 16, 2010 | Motorola Mobility Motonav TN30 Car GPS...
RECEPTION NOT STABLE
its the battery problem in your device.just remove the battery from your device for some minutes and clean the internal area where the battery is fitted and also clean the battery with a dry tissue paper.and reinsert the battery and check out.if it still gives the same problem .then its necessary to replace the battery.as this problem which you r facing happens due to weak battery.and battery goes weak if the mobile is overcharged for more then required time.the battery goes weak slowly ---slowly.and this happens. thanks.
Jan 07, 2009 | Nokia 7610
Garmin C330
Make sure that at its location it can have access to see the satellites.
It is also possible that its front end receiver is starting to become weak in performance due to some failing parts.
Jerry G.
Jul 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Nokia E71 Smartphone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
