Question about IBM ThinkPad R31 2656 Notebook
I can not start laptop because it stays in sleep mode.
I click on the power button and find the laptop is in sleep mode. I don't know how to get rid of this condition.
  • dfinecy Nov 20, 2008
    This is an xp machine.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    is this a vista or xp machine please?
Kind of stupid to tell someone to go to control panel when he can't even get out of sleep mode first isn't it?
Posted on Apr 05, 2009
  • 458 Answers
Do A "Cold" Boot...
Remove The Battery For 30 minutes, And Leave It Unplugged..
With No Battery in and No Charger Cord Plugged In Now, Press and Hold the Power Button Down For 30 Seconds.....
After 30 minutes, Replace Battery and AC Adapter and Attemt to power on "hopefully not in sleep mode"
Posted on Nov 20, 2008
  • IBM Master
  • 4,806 Answers
Ok, go into the "control panel" and select "power options" click the "power schemes" tab and set monitor, hard drives and system standby to "never" then click apply and ok computer will never go to sleep again
hope this helps
regards
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
How can i get my toshiba satellite not to go into standby while watching movies
To keep your laptop from going into standby mode you want to change the power settings. To do that, click on the start button/windows logo to open the start menu. Then click on control panel, or if you do not see it start typing control panel. Then go to power settings. You then need to change the advanced power settings for your battery options. Change the power settings so that it does not standby at all. Another thing you can do is plug the power cable in and that way it also will not enter standby mode.
Thanks for using FixYa!
Jul 11, 2011 | Computers & Internet
When I press shut down, the laptop screen gets off but the power button stays on and the laptop stays warm too. I have to press power button for 5 sec to turn this thing off. When I start it I don't...
hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards Anas K A
May 29, 2011 | Dell Inspiron 1545 Notebook
I have an EVESHAM MS-17188B Laptop. Stuck in sleep mode! The Problem is when ever I turn it on, the power and sleep mode light is active. But nothing else, the screen stays blank, and cant hear any fans...
First advice would have been to remove battery, but since you did that, I'd say that your laptop is stuck in hybrid-sleep, or the old hibernate. Try pressing the power button for 10-15 seconds, the laptop should go off, then try presing the power button again, for normal boot.
May 05, 2011 | Computers & Internet
Acer aspire 5610z will not go into sleep mode, either by closing laptop, or by selecting 'sleep' from Start button. Stays on, but without screen - then has to be turned off and on manually.
Try to go into the energy management settings (by clicking the power mgmt icon in your system tray) and seeing what your sleep settings are. You should be able to customize your sleep settings to do more than turn off the screen.
Dec 24, 2009 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad R31 2656 Notebook Logo
676 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
