Question about NEC VT460 Multimedia Projector
Project will not display entire computer desktop
When projecting - it appears to display in a wide screen mode and you have to scroll up and down to see the entire desktop. Yesterday, it projected normally. Any suggestions?
  • 4 Answers
Hi, have you checked the zoom function, or magnify function?? Try zooming out in case in accidentally go zoomed in.
Posted on Nov 22, 2008
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Pc to tv connection keeps scrolling vertically
its probably your caps on the signal module
c2p05 and c2p08 100uf 16v capacitors
did the problem used to only happen when it was cold? = caps
is there rolling bars? is it a dark unstable picture? = caps
let me know if you need further assistance, the caps solder in
Jun 18, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have conected my laptop to a projector using a rgb connection and get the bootup picture from my laptop onto the screen then it dissapears and just shows a blue projected screen. I have tried using Fn...
try to restart your laptop into safe mode with still the projector connected. notice if your safe mode desktop appears projected as exactly as your laptop's desktop screen. if so, you only need to further configure your display settings.
Dec 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Full Desktop does not appear, video does not show.
You must tell the laptop to change display mode--there are 3...Normally, the key-press is something like "function key, F4"--look for a small tv screen symbol on one of the "F" keys--default mode is "laptop only", Press and hold "fn" and then press the appropriate "F" key, the laptop will switch to "laptop/external display". Another set of key presses will get "external display only" mode. And, finally, the next sequence will bring you back to the default mode. Make sure you turn on the computer and *then* turn on the projector to head off any sync probs.---Rick
Sep 21, 2009 | CTX Optoma EzPro 710 Multimedia Projector
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
On wide screen mode screen flickers at top
hi there,i spoke to samsung direct and they said switch tv to standby,then press info,menu,mute then standby wait 15 seconds. then switch tv back on a secret menu appears on the screen arrow down until 12.reset arrow right on remote and follow instructions very easy hope this can help.
Jul 14, 2008 | Televison & Video
Presentation mode is off...
I'm going to guess that you have a wide screen Dell laptop with a 16:10 aspect ratio and a default resolution of 1280X800. The wide screen is great BUT most presentation grade projectors do not have a native (pixel for pixel) 16:10 mode. Instead they still prefer a display input with a 4:3 aspect ratio like your old square CRT or standard definition TV. Why do they prefer a 4:3 input? Mainly because Powerpoint prefers to display a slideshow in a 4:3 mode. Because of this Dell, in their infinite wisdom, created the 'presentation mode' utility in an attempt to automatically convert the VGA output of your laptop from 16:10 to 4:3 on the fly. In my experience this is an annoyance at best and at worst can seriously impact the size and quality of the projected image.
The best thing you can do when you connect to a projector is ignore the presentation mode alert and manually set your laptop's resolution to 1024X768 for an XGA rated projector or 800X600 for an SVGA rated projector. This will cause your desktop to look stretched on your laptop but will give you by far the best projection image.
Jan 16, 2008 | Panasonic PT LC75U Multimedia Projector
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
Display size problem
Sound very much like you are in 16X9 mode with a 3X4 signal. That is not uncommon. Do you lose any information, top or bottom with a HD signal? Bink.
Apr 20, 2007 | Sony KDS-R50XBR1 50" HDTV
NEC VT460 Multimedia Projector Logo
147 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
