Question about Dell Inspiron 6000 Notebook
No audio when connected to tv with s-video cable
I have an inspiron 6000 want to watch sec volleyball play-offs pluged up great picture no audio i am pluged into front of my dvd player wanted to burn as i watched
  • 458 Answers
Then you need to connect audio, either from an onboard audio port or your audio-out port which you will need an adapter to plug into the audio out then convert to RGA compatable connector which will plug into your tv audio in port
Posted on Nov 20, 2008
I have the receiver hooked up to a Sony TV via component video. When watching cable TV the colors are really off on the TV. However, while watching a video (DVD), the TV's picture is great. Is this a...
I don't know what kind of tv you have but, receivers can pass video along to the tv but, are not the best way to go. If you have the capability of running your video components dirctly to tv then sound out to receiver, you would get better results. Component video is great, as good as or, better than HDMI, the only advantage to HDMI is the audio but, digital optical for audio is great also. Component video cables can be tricky because you have to make sure the connectors are in all the way. If they are not inserted properly, you probably notice too much blue or green. While watching your cable, try twisting and pushing connectors and see if you notice any change in the color quality
May 22, 2011 | Onkyo TX-SR602 Receiver
Have alot of buzzing noise when we play a DVD but not when watching tv.
Verify the AUDIO cables from the DVD player to the TV they could be defective (even if new)
push the PLUGES firmly so they are correctly seated, play with (shake/move) the AUDIO cables while playing a DVD to see if it's not a loose connection
Cheers!
Jan 14, 2011 | Vizio L32 32 in. LCD HDTV
No picture on TV with Dell Inspiron 6000
the problem is your video configuration its supposed to be Tv-in on computer so you can receive video on the laptop screen
Jan 25, 2010 | Dell Inspiron 6000 Notebook
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
S-video problem for inspiron 6000
You will have to look at your TV to see what type of interface it has for PC connectivity, this is because there are 2 types of Video out on the laptop, first the s-video and secondly VGA (D-SUB).
I would recommend the VGA connection as the quality of the picture will be much better than s-video, so you will need a male to male VGA cable if your TV takes that interface (a male to male mini stereo cable is also required for audio)
If your TV only supports s-video then you are stuck with that interface until you upgrade your TV.
If you need anymore help in this matter please don't hesitate to post back.
Regards
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Sound thru tv
You will need a cord that plus into the headphone jack or speaker out jack on the computer and has rca end to plug into the audio input on the TV.It will look like the one pictured.Please rate this solution.
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
How do I get video input from one source and audio from another?
I am confused and might be overlooking something obvious here. SO PLEASE do not think I am being disrespectful! IF you have everything connected properly, then your television is a separate device, independent of your Sony STR. You should be able to watch the picture with the Sony STR turned OFF. In turn, you should be able to LISTEN to the Sony STR with the television turned off. Although it isn't a lot of fun, it might be best to DISCONNECT all the cables (not your speaker wire) and go through the process of reconnecting everything.
Jul 09, 2007 | Sony STR-DE597 Receiver
Dell Inspiron 6000 Notebook Logo
93 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
