Problem switching between 480 and 1080i modes (get blue screen)
When using the HDMI cable mode, the set sometimes successfully switches between modes but often I get a blue screen. Once I get into a 480 mode, surfing the channels isn't a problem. In 1080i mode, when I surf the channels I'll encounter blue screens. If I use component cables, the set works fine.
Mitsubishi replaced the main board in the set but the problem continues.
    Scholar:
  • 146 Answers
Make sure that you have the latest software version installed in your tv. You can down load it from the Mitsubishi web site.
Posted on Nov 20, 2008
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  1. Switch everything off.
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V HDMI Reset
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Why does my Samsung HT-5400 receiver switch modes automatically?
We are having the same issue for the past few weeks. The system worked fine for a few months before hand. Were you able to get it resolved?
Sep 04, 2012 | Samsung Ht-e5400 5.1 3d Ready Blu-ray Home...
I am trying to connect a playstation 3 to my tv using a hdmi cable but it says "no support". i can hear it but there is no picture.
Try connecting it using HDMI and the standard composite video. Then when you press the power button on the PS3, Press and hold it, it will beep once for turning on, then beep again, once you get the second beep, release the button. Switch your TV to the composite mode and go to your display settings. Then change your display settings to the HDMI cord and the screen will most likely go black. Then switch your TV to the HDMI mode and finish the settings change. Then, change the audio settings to audio as-well. Hopefully this helps. Nathan Taylor.
Jul 17, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Vizio 46" hdtv. when turning on the tv, the blue screen come up but the switch in side will on not allow antenna connection to come up. it will go to the av, component, hdmi. but not the tv mode..
Try pressin the channel up/down button instead of the input button. Sometimes this will activate bring up the cable/antenna input...
Good Luck....
Jan 08, 2010 | Televison & Video
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
My projector optoma ep719 has a blue screen went turn on with or without cumputer hook up
please check the signal and the display properties as per SVGA or XGA resolution
Jul 16, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
"Normal" picture option is gone
Have you switched inputs? Some sets when you are on component/ HDMI/DVI will only allow a couple of PIX modes, Antenna will usually allow you to use all of your modes, If you have a cable box they sometimes will also have format modes. Try switching to cable channel 3 (if you get it or have a box on that) and changing format, try a VCR or something if no cable ch 3.
Jun 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
