Question about Gateway Convertible CX2620 Notebook
My cx2620 gateway
Hi
Ok if the battery is bad ? will my laptop not trun on ???? I went to turn it on and a red light flashed four time and not i can not get it to charge or turn on !!! what do i need to do ??????? Please help.
  • plumopal Nov 20, 2008
    my laptop will not trun on ........ There was a red light that flashed four times and now it wont charge or turn on .. what do i do to fix it ....
  • tdirkes384 Mar 20, 2009
    gateway mx8734 battery meter is at 25%, tried two other good solid power adapters - NOTHING only the red flashing light .... any solution?!
My laptop will not load farmville all he way
Ok download flash player and install, also get Java runtime as well.
Feb 16, 2010 | Gateway Convertible CX2620 Notebook
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
Gateway laptop model W350i will not boot. When power button is pressed, red light flashes four times. Replaced AC power adapter, tried removing battery and power with AC only, still does the same thing. ...
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Jul 12, 2009 | Computers & Internet
Every time i try to turn on my Gateway model MA7
  • the battery may need full charging, charge it for 4-5 hours, and it the problem persist it needs replacement.
  • for it works in power cord.
May 03, 2009 | Computers & Internet
Cant get it to turn on or charge
Flashing red light 3 times and won't boot. I recently recalibrated the battery and again the 3 flashing red lights. Seem to be draining the battery fast. It's also a new battery...which work for about 2 weeks before the 3 flashing red lights first started. Now 2 batteries later. It won't boot.
Apr 26, 2009 | Gateway MT6840 Notebook
No Power to Gateway Laptop
Michelle,
Check the fan vents... if they are clear of dust and lint. If there is some it may need a cleaning inside also.
Since the battery is light is "red" remove the battery. It could have been over heated or shorted outinside.
If it dont power up at all with only the AC adaptor (removing the battery) then try the reseting the "Reset" button under the unit.
Jan 03, 2009 | Gateway Computers & Internet
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Gateway cx2620 pen replacement tips
Go to www.mundocorp.com. They sell Gateway Laptop repair parts. THey list the Stylus for about $44.00 US Which is a good deal. I paid $89 CDN for my replacement direct form Gateway whey they were still available there.
Aug 28, 2008 | Gateway CX2610 Notebook
Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
Mar 12, 2008 | RIM BlackBerry 7290
Computers & Internet Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
