Question about Canon PC981 Copier
Error message for auto feed
I have a Cannon PC981, and the automatic paper feed keeps giving me an error message saying that theres a paper jam, yet I can not find any. Is there a way to reset the sensor, or how do you clear the track? Please help.
  • 883 Answers
The rubber feed wheels need cleaning with high purity alcohol
Posted on May 20, 2007
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
My brother printer mfc-j415w keeps giving me an error message which says paper jammed, I removed all paper and bits of debris found in between the rollers but it still keeps giving me the same error m
there will be paper to the side of the printer which is stopping the carriage from travelling fully which will also be why it makes a noise.
If its to the right of the carriage, start printer and when carriage starts to move pull the power lead, you'll be able to move the carriage out of the way and look in with a torch to find the paper or foreign object. Just remove it and restart the printer and everything will be normal.
Please indicate if it fixed your problem here.
If you need ink for this printer go to our site:
http://www.the-inkstore.co.uk
Jan 29, 2013 | Office Equipment & Supplies
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Error message "servicer reqired 10"
Please email to d_atwood@gccprinters.com for a solution. Mention the error message # 10
Feb 02, 2009 | GCC Technologies Elite 12/1200N Laser...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
PC981 copier
Your copier is rather old, and this is one of the "classic" symptoms for small Cannon units. I just stops working. Please do not waste your time and money trying to get it fixed; it will not last and for a little more cash you can buy a Samsung digital copier (such as the SCX-4521f).
May 04, 2007 | Canon PC981 Copier
206 people viewed this question
old marine
old marine
