Question about Brother IntelliFAX 4100 Laser Fax
The 4100 Printers in my office make a horrible grinding noise. The drum units constantly need replacing because they get stripped out and the grinding noise starts again.. Is there a more permanant solution to getting rid of this noise other than replacing drum units constantly? Is there a wheel or something inside the fax machine that is causing the drum units to strip and create the grinding noise?
  • 328 Answers
Definitely drum drive gear is cracked or stripped. Can be replaced by qualified tech. Part costs a few dollars. Alot of tear down involved. I charge about $75.00to repair that problem
Posted on Jan 12, 2009
  • 80 Answers
A good solution it to go paperless and get a fax number that sends faxes to an email address. Then train your staff to send faxes from the pc they use. Many copiers can be set up to be fax machines as well.
Posted on Jan 09, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Seems like the drum drive gear is bad, and is not meshing w/the drum causing it to strip the drum gear.
Posted on Nov 21, 2008
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Sharp AL-1655 CS copier - machine is 4 years old and has new TD cartridge. It was dumping excessive toner which I cleaned up. Also, made grinding noise. When machine opened and TD cartridge removed, I...
The part that you are talking about is not from the fuser unit. It is from the drum unit, it is most likely the primary charge grid. It is part of the drum that charges the drum..... You may just want to replace the drum unit..... If the grid fell off the plastic holder may be broken... Good Luck
Mar 31, 2011 | Sharp Office Equipment & Supplies
Horrible noise
do u have fixed properly drum unit do u have tested with the older drum is the same i think you dont have fixed proply thats ywhy u getting noise from gears just try to fix proper thanks
May 12, 2010 | Brother IntelliFAX 4100 Laser Fax
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Brother IntelliFAX 4100 Laser Fax Logo
313 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
