Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Display problem ina lcd monitor i got a problem some wawes cominig i changed frequency but same prbm here how can i solve that prblm
  • 1,602 Answers
IF IT CONECT TO A PC THAN YOU HAVE CORRUPT DRIVER AND NEED TO GO INTO PROPERTIES OF VEDIO CORD SELECT DRIVERS UPDATE AND REBBOOT THE SYSTEM
ROD
Posted on Jan 29, 2009
I feel my ASUS monitor is bright to my eyes. I checked and found the frequency of the monitor is 60Hz. I want increase the frequency of my monitor. How can I do it? I want to my eyes feel comfortable for...
On nearly all LCD monitors the frequency cannot be raised above 60 Hz. This is due to the way LCDs are displayed, which is very different than CRT monitors (on a CRT, you can select a range of refresh rates)
Mar 03, 2011 | ASUS VW224T 22 inch LCD Monitor
My samsung syncmaster 943 bwx turn black after few second turn it on.1st i thought is the software change it .but it seems not . I try to solve it since i noe some basic . waw gt many bad capasitor and...
When DC filter caps are bad, the circuits will get AC ripples feeding the inverter output circuits and caused it to run at worng frequency and caused it to over heated, hope fullly it did not take out the MOSFETs.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 20, 2010 | Samsung 943T Monitor
Monitor turns on and off by itself
check whether have u connected monitor-cpu cable properly.. did u change frequency in graphics option??? soon after u switch on ur system u press ESC for sometime n c whether ur prblm gets over
Sep 21, 2009 | Computers & Internet
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
Out of range frequency
Lower the PC display resolution to a lower refresh rate.
Jan 09, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a problem with FPD1975W-UK TFT LCD Monitor gateway, out of frequency on the startup of computer, dark screen.
You set your computer resulation to do things to the monitor that it can't do. try to boot up in " Safe mode " goto >control panel>DISPLAY>SETTINGS and change resulsation. You may also "flutzz" with a software program that changes the frequence of the monitor.Find that program and lower the frequence.
Nov 30, 2008 | Computers & Internet
On My LCD monitor every time displays Auto Adjusting
It might say that when changing resolution or frequency in order to line the corners up with out cutting off. Might also be video card sending it mix signals too.
Apr 22, 2008 | HP f1905 19" Flat Panel LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
