Question about Kenwood CD-206 5-Disc CD Changer
Track # shows EE under each disc slot
Kenwood mutiple compact disc player DP-R99. I have tried the disc in each slot. Also when the EE shows up I can not open the disc player.
2 Suggested Answers
SOURCE: my kenwood dp-r99 reads ee
I just took my DP-R99 out of the closet and powered it up in my garage. After a short delay it reads EE. I took it apart and the belt that drives the laser head up to the CD and pressure disk to make it spin is slipping and never raising the head enough. It looks like the belt has stretched over the years. I am now going to look for a replacement belt and the belt that rotates the carriage since it is also stretched. I will let you know for sure when I install new belts. Hope this helps...
Posted on Jul 05, 2009
smarthome2
  • 1114 Answers
SOURCE: i have a kenwood dp-r99 cd player and the cd is stuck
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Posted on Nov 07, 2009
Alignment adjustments
most newer model optical pickups take no manual focus/tracking adjustment.
May 28, 2013 | Kenwood Audio Players & Recorders
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Dec 25, 2010 | Kenwood DP-J1070 100-Disc CD Changer
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
I have a kenwood dp-r99 cd player and the cd is stuck inside with an ee message. How do I open the CD player?
Nov 07, 2009 | Kenwood CD-206 5-Disc CD Changer
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
My kenwood dp-r99 reads ee
Jun 06, 2009 | Kenwood CD-206 5-Disc CD Changer
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
Repairing Kenwood mutiple compact disc player
get lens cleaning kit cd that has micro brushes on it to clean yuor lens ok dirt
Jan 30, 2008 | Audio Players & Recorders
Remove DISC010 error
If there is a disc in the changer (I guess it's in the tenth slot), try removing it, if it doesn't work by 'normal' means and you feel brave, try shaking the unit a bit. If it doesn't help or you don't feel like banging on it, you'll have to take it for a repair (they open the unit and extract the disc, they get jammed sometimes).
Nov 05, 2005 | Kenwood CD-423M 200-Disc CD Player
Kenwood CD-206 5-Disc CD Changer Logo
97 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
sonic boom...
sonic boom...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
