Question about Samsung Televison & Video
Model: Samsung 47w3hf - Convergence problem?
I got home last night, switched the tv on and the bulbs aren't projecting correctly. basically the screen is off colour - greenish, reddish, blueish tint and there's like 2/3 cast of the same image. is this a convergence problem? i tried auto convergence and no luck.
how do i get parts etc. i can build computers, solder etc - so thought i might try to repair. but i can find service manual online.
please help.
thanks
  • tincan1977 Nov 21, 2008
    Many thanks.
    Is there a service manual floating around on the internet?
    I tried to open the back part last night.
    The bottom back cover appears to be sticking - i'm sure I've taken out the screws.
    Rather stupid question but how do i clearly remove the back piece of black cover?
    As I don't have a service manual i can search for the two ICs - but for ease can you give me heads up where I should find it? is it horizontally/vertically mounted etc.
    Happy to take a punt at the ICs cos that's cheap for a repair.
    Cheers
    Habit-Forming:
  • 166 Answers
YOU ARE GOING TO NEED 2 X STK392-010 INTEGRATED CIRCUIT THE COST OF WHICH CAN VARY BETWEEN £20 AND £45 EACH AND SOME SKILL IN FITTING I c`S AND THIS SHOULD CURE YOUR PROBLEM.
SUPER8
Posted on Nov 20, 2008
  • JOHN TOPLISS Nov 22, 2008
    Hi, the two I`cs are quite large ones about 3" long 2" high and mounted on a heat sink you really carn`t miss them, atleast not when youve got the back off.which is just the lowerpart of the back and it wraps round to the front.GOOD LUCK.
    SUPER8
Where is the projection bulb on my Hitachi 65s700 65 inch
Hi Anonymous,
There is no "Projection Bulb" for this model. It as a 3 tube Rear Projection TV. The most common problem is Convergence Failure as in the link below.
Calgary Hitachi Big Screen In Home TV Repair Service
Robert
Nov 12, 2015 | Hitachi Televison & Video
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Televison & Video Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
