Question about HP Compaq Business Notebook NX9010
HPCompaq nx9010 power switch broken
The power switch on my nx9010 has 'dissapeared' above the hole it should be located in and I can't turn it on.
How can I fix/repair this, please.
Is there an alternative method of getting it to fire ?
  • darthan Nov 20, 2008
    Thanks guys - by using both solutions offered I got the plastic panel off and got it started up. Once I got the cover off I could see that the microswitch is actually about 3/16" to one side so the pencil trick didnt work initially.
    Will now try to refix the button.
    Thanks again!
  • HP Master
  • 4,806 Answers
You should still be able to boot the machine even if the on/off button is missing, try poke the flat end of a pencil down the hole and apply just a little pressure and pull the pencil out and the laptop should boot, to reapir this you need to remove the panel that goes accross the top of the keyboard, this can be hard to do because of how they are clipped together, you should not have to remove anything else because this will reveal where the "power on" board is, all you need to do is replace the button or the panel, you may even find the the original button
hope this helps
regards
Posted on Nov 20, 2008
  • 458 Answers
You need to take the plastic panel off that houses the power switch... (some just unsnap from the base and some have screws holding it in from the underside..) the power switch connects to the underside of it, it is kept in place by melted plastic rivots.... So If you can retrieve your power button from inside the laptop, you can replace the button and super glue the contacts where the button was previously rivoted.. that way it will still have its " springiness" feel and work the same as if it was the plastic rivots...
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
My hardware radio switch is off how do i turn it back on please
The Wi-Fi indicator light is on the top right above the keyboard.
The switch to turn Wi-Fi on is located on the Left side.
There are a series of 10 vent holes. 5 across the top, 5 across the bottom.
Looking at the vent holes. Underneath them is the Wi-Fi switch. It is the switch that is closest to the Front.
(The Front of the laptop is towards you)
To turn it on slide the switch forward, and let it release to the middle position.
Nov 02, 2010 | Dell XPS M1210 Notebook
How do i turn my wireless on my laptop
front
Hope it helps !
Jul 14, 2010 | Advent Netbook
I don't know how to turn on wierless
> front
Or you can do that from device manager.
May 31, 2010 | Dell Latitude D610 Notebook
Can't access CD
If you mean the drive won't open then
Turn off computer
Locate a small hole in DVD drive lid.
Carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & remove the CD
Restart the computer and see if it opens normally and reads dvd's now.
If you mean Windows won't read it then the drivers may need re-installing. Check in hardware manager to see if Windows recognizes it or shows an error for it.
May 17, 2010 | HP Compaq nx9010
Please i'm in a fix to get multimedia audio controller driver for my compaq nx 9010. Please i need your help
click here
Downlaod driver from above link then install in your computer.
Then it works fine.
Click on above link then select your operating system and download driver.
Let me know if you need more assistance.
Thanks.
Oct 07, 2009 | HP Compaq Business Notebook NX9010
Laptop switches off immediately after powering on
Try powering it on with the battery removed. I have seen some laptops where if you have a bad battery it will cause boot issues.
May 12, 2009 | HP Compaq Business Notebook NX9010
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Compaq nx9010 notebook
Hello, this is the inside of your laptop:
So the fan you see at the rear pulls in cool air for the main processor & it exhausts on the left hand side through a grill which you can see. It should spin up on power up of the laptop & you should fell air moving out of this vent. It is most likely temperature controlled so will only come on when the processor gets hot. If the laptop is running hot and the fan is not spinning you need to have it checked.
You can download the service manual on the following link:
nx9010 service manual
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 07, 2008 | HP Compaq Business Notebook NX9010
HP Nx9010
Is it completely dead?
Jan 25, 2008 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9010 Logo
381 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
