Question about GE JGBP28 Gas Kitchen Range
GE gas oven won't heat
My GE gas oven stopped working. I replaced the ignitor and now the broiler works but the oven still won't. What could be the problem.
  • lpkuntz Feb 11, 2009
    Broiler works Oven dosn't , all of a sudden 6years old
Replaced glow plug its getting current but still not glowing. Tested resistance 1100 showed good,
but glow plug still no lighting
Posted on Dec 13, 2008
    Habit-Forming:
  • 171 Answers
Did you do it your self or did you have some one else do it for you? I ask the question because the electricity most be unplug before you do it, If any of those wires made contact or spark. Now the safety valve it's also bad, you can test that by putting a tester for the 2 wires that connets to the ignitor to see if you are getting any power when thermostat is on. if there is power replace ignitor, if not getting power replace safety valve. Or maybe your clock is set on automatic, Set it on manual.
Posted on Dec 07, 2008
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
My GE Single Gas Oven won't light, the broiler works. My husband can put in the part, what part do I need.
heatman101
oyuou
Nov 09, 2009 | GE JGRP17 Gas Single Oven
GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Aug 28, 2009 | GE Kitchen Ranges
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
GE JGBP28 Gas Kitchen Range Logo
188 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
