Question about Acer Aspire 3680 Laptop
Magic Jack will not initialize , however the demo for magicjack r
Magic Jack shows " plug into USB port. It is not setting up to use , however the demo for magicjack starts playing I have unplugged the magicjack, restarted the computer, Etc. with still no solution
  • 5 more comments
  • pjm123 Dec 05, 2008
    Same problem, with NO HELP from company. They won't even answer their chat line!
  • dbbenny Dec 16, 2008
    it does same here i have 1 drive says MJ other removable disk leave plug in after warning i format the removable drive. then restart MJ must give email password works fine til shutdown/standby
  • dbbenny Dec 22, 2008
    just to update a fix was sent through and my MJ is
    working better now I can go on as normal after shutdown/restart. Simply restart MJ after standby.
    So I wouldn't be quick to replace the device with
    another. I about was, glad didn't now.
  • Anonymous Jan 13, 2009
    hi! my anti virus deleted my magic jack drive.. not it'w not working. everytime i plug it in, it says" please plug your Magic jack to USB port".. help!
  • Anonymous Feb 04, 2009
    same
  • Anonymous Feb 20, 2009
    when plugged in the usb port a warning message ask me to plug it in usb. I tried in three computers with the sane result. previously it was working properly. Please help.Can i get the fixit for magicjack .will it work
  • aeljack2 Mar 14, 2009
    I had the same problem and finally it would not even load the magicjack program. I called them and spent several hours trying to troubleshoot the problem with a support person. I even got a message "Defective Jack. Please contact Support".
    I was disconnected from the support chat and could not connect back to them - there was a problem cookie problem "I am wondering if this was done on purpose so that I would not be able to reach them" - I cleared my cookies and was able to connect again - this time they went through the same process only to tell me to contact Radio Shack where I purchased the unit for a replacement. But they would not send me an e-mail to confirm this. I am assuming I am going to get the runaround between radio Shack the MagicJack - we shall see I will keep you posted..
After 2 days of frustration I was able to solve this by the following:
1. Click Start
2. right click my computer and select properties
3. select hardware then Device Manger
4. click + DVD/CD-ROM Drives
5. right click Tiger Jet CD-ROM USB Drive then Uninstall
6. unplug Magic Jack wait 15 secs
7. Plug back in and let device re-install, MJ may start here, if not...
8. Click Magic Jack Icon, program should start
I have to do this everytime I unplug or restart my computer. I don't know exactly why it hangs like this but this procedure works for me everytime. Good Luck
Posted on Mar 08, 2009
    Problem Solver:
  • 30 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 20, 2010
Delete magic jacks folder in user names application data. can just move it out if want.
format MJ's removable drive. I ntfs allocation size 1024 in pulldown options for format.
unplug magic jack wait seconds it does the run through may want the latest upgrade too
now at this point it works Copy the files placed directly on the Magic Jack removable drive
save to a folder in documents from this point on
Just format removable drive and copy files you saved back to MJ drive.
its faster this way and you avoid the step off logging back into your account since already in saved files.
1 thing may need to update your copy of the files to have latest copy if use a lot of contact numbers.
hope this helps while I chatted with MJ ops hours and hour few helped most sent me in circles.
Posted on Mar 30, 2009
  • dbbenny Mar 30, 2009
    once MJ works it last a while I think MJ was have trouble loading with a windows update or antivirus
    all loading. So will work until you makes changes to you r computer. Just keep the back up MJ files
    handy
    Problem Solver:
  • 5 Answers
I had this same problem, I was frustrated for days, this is what worked for me:
http://www.ehow.com/how_4802284_magic-jack-work.html
I hope this helps. Thank you
Posted on Feb 25, 2009
  • skinzo89 May 04, 2009
    The above link will not give you a solution, sorry. A well explained answer to this MagicJack problem can be found here:http://www.infobarrel.com/MagicJack_USB_...
    Problem Solver:
  • 6 Answers
I was having audio and connection problems until I solved the technical problem of my computer's USB bus drawing over 500 mA, actually 580 mA, with everything plugged into the bus.
Power-Hungry USB Ports The number of USB devices that the users can plug into the computer these days, with cameras, scanners, printers, keyboards, pointing devices, PDAs, hard disks and many more peripherals using the USB interface that often runs off the computer's power through the USB bus. This is more of a convenience since the users don't have to plug in a separate electrical cord, but it's also easy to overload the USB ports if the users plug a number of devices into many of the available ports.
Does the user's PC's USB ports supply enough electricity to power all the devices they have attached to them? Plugging too much gear into a bus-powered USB hub (one with no external power adapter) can overwhelm a USB port by demanding more than the 500 mA it can supply. Check the power demands on any USB port in Windows XP by right-clicking My Computer and choosing Properties, Hardware, Device Manager. Double-click Universal Serial Bus controllers, double-click the USB Root Hub entry, choose the Power tab, and add up the amounts in the "Power Required" column.
(Below is the advice which many users forget about.)
In a few rare instances, the USB port on the user's computer may not have enough electrical power for the magicJack® dongle to work properly.
Try using a externally AC powered USB hub to plug the magicJack® dongle into instead of using the computer's USB port if there are 'many' other USB devices connected to the computer or if the magicJack® dongle acts erratically with audio and connection problems. »(Cost $20.00)
magicJack® may or may not work best when plugged directly into a USB port on the computer.
Do not plug the magicJack® dongle into a multi port USB hub that is not AC powered.
After the user has connected the magicJack® dongle for the first time, registered the device, and has the 'softphone' on the screen, the user should probably run TCP Optimizer to “tune” the computer to work with it in an efficient manner; it can be downloaded from the following website:
http://www.speedguide.net/downloads.php
The program can aid both the novice and the advanced user in tweaking related TCP/IP parameters in the Windows Registry, making it easy to tune your system to the type of Internet connection used. The tool uses advanced algorithms, and the bandwidth delay product to find the best TCP Window for your specific connection speed. It provides for easy tuning of all related TCP/IP parameters, such as MTU, RWIN, and even advanced ones like QoS and ToS/Diffserv prioritization. The program works with all current versions of Windows, and includes additional tools, such as testing average latency over multiple hosts, and finding the largest possible packet size (MTU).
The user can use the TCP Optimizer by following these short instructions:
1. Choose the maximum Connection Speed from the slider bar (the maximum available bandwidth, in kilobits per second)
2. Choose the Network Interface, or check to Modify All Network Adapters
3. Pick "Optimal settings" from the radio-buttons near the bottom of the program
4. Click on the "Apply changes" button and reboot
Posted on Dec 28, 2008
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Thanks for all your help on ram chip now here is some thing no one has ans.
What is the setting on your computer for the clock? Make sure it is right.
Jan 12, 2015 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
How do you get rid of time zone New Zealand?
. You can change the clock's time and time zone.
  1. Open Date and Time by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
  2. Click the Date and Time tab, and then click Change date and time. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the Date and Time Settings dialog box, do one or more of the following:
    • To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
    • To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
    • To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
  4. When you have finished changing the time settings, click OK.
  5. To change the time zone, click Change time zone.
  6. In the Time Zone Settings dialog box, click your current time zone in the drop-down list, and then click OK.
Aug 19, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
After turn on my computer I have only three short beep.
Open the cpu cabinet cover.Then reconnect the RAM memory into motherboard. Make sure motherboard is not ground with cabinet cover. Clean dust from motherboard .If there is any pci or vga card reconnect it. Also pull cmos cell from motherboard for 10 minutes then all settings defaults then check. Let me know if you need further assistance. Thanks for using FixYA.
Feb 03, 2011 | Computers & Internet
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
Thanks.
Mar 08, 2009 | Computers & Internet
Acer Aspire 3680 Laptop Logo
1,354 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
