Question about RCA D52W19 52" Rear Projection Television
Rca d52w17byx1 chassis itc222 question
I've been having the long squeal before startup and then the other day there was a bang and the tv turned off. now on attempted startup, the tv turns off and then trys to turn on twice more. i've read that it's more than likely the flyback, but i'm just curious if you'd have a different opinion?
  • skawt Nov 28, 2008
    thank you very much, i will be ordering these parts in the next week or so and will let you know how it works out for me. i appreciate the help!
  • skawt Dec 27, 2008
    well, it looks like i am successful in my first television repair so i'm deeply indebted to you slinteriors! i just had one question, when i first fired it up and got a picture, the screen flickered every once in awhile... then became totally stable. is this just the flyback easing into it's new role and dealing with it's newfound high voltage? i'll plug it in and run it all day on sunday just to be sure that it's working right before i put it back into it's final resting location.
    thanks again
    skawt
  • RCA Master
  • 8,617 Answers
Its the flyback that causes the 3 blink then nothing . You need flyback 265409 also will most likely need CP150, and CP114 and CP120 You can get replacements at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Posted on Nov 28, 2008
  • Sonny Berry
    Sonny Berry Nov 29, 2008
    Glad I could assist you, you will like the instructions they send. Very detailed and very easy to follow.
  • Sonny Berry
    Sonny Berry Dec 27, 2008
    Yes its often normal for the screen to flicker briefly after replacing the flyback untill the focus lead bonds inside the new flyback connection, also sometimes the ribbon cables will cause the flicker as well till they are warmed up to normal operating temperatures. Glad that I could assist you.
RCA TV Model D52W23 when turning on light blinks and does not turn the tv on?
Look if have not done so at flyback to see if broken solder connections around it.
May 02, 2012 | Televison & Video
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
Apr 13, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
