The viewing lens is cracked and causes the viewing area to show up as predominantly black. What is the cost of a new view finder and is it worth it with the camera being 5 years old?
SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
SOURCE: LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
SOURCE: broken lcd screen on my sony dcr-sr45
LCD view screen consist of 2 pieces of cabinet and LCD screen including circuit board inside.
Do you need LCD cabinet only or require LCD screen too?
SOURCE: i have a sony dcr-hc32
There is connecting ribbon wire between LCD board and Camera main board and this ribbon wire is cracked and needs to be replaced.
Let me know if you want to replace it at own to provide you part number.
SOURCE: LCD Screen not working, no way to operate cam or
There is flexible connecting wire between LCD board and main board of camcorder that is broken and requires replacement.
If you can apart camera and exchange that wire then let me know to provide you part number info of flexible wire for Sony DCR-HC21 Camcorder.
