All its doing is blowing cold air
SOURCE: Electric Dryer
Dont see a model # or make but here some tips You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuse that need to be checked for Continuity and replaced if bad if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
I hope this helps....
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
