Question about HP Compaq Business nx7010 Notebook
Laptop won't start
I have either a power or motherboard problem.
When I press the power button nothing happens, either when connected to the AC adapter or only with battery. Sometimes there is a quick flash of the power light, but that's it.
If I keep plugging the power cable off and in all the time while keeping the power button pressed it may start, but it usually takes about 30 times.
Is it the motherboard? The laptop is about 5 years old. How much would the repair cost? Is it worth getting a new one?
Thank you
  • 40 Answers
If you can afford it a new laptop will be your best bet. They have really come down in price. I have a Compaq laptop that had the same problem. If I took the battery out and keep it unplugged for a few days it would boot up but only for about an hour then shut down and not reboot until I did the same thing. This has gone on for about a year. I even disassembled it , put in a new CMOS battery and the same. I was just about to give up on it and one day it just started working and has been for about a month now. I'm sure it is going to go back out but it will give me a chance to do some more testing on it. Hope this helps.
Posted on Nov 20, 2008
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Laptop will not come on at all
You can try to reset hardware using following steps
1 Disconnect battery and ac adapter
2 Wait for 5 minutes.
3 Press and hold power button for 60 seconds and then release power button
4 Connect adapter (do not connect the battery ) and try to start by pressing the power button.
If it does not help, check ac adapter next
If the adapter is good, there can be some problem with motherboard
Sep 19, 2011 | Computers & Internet
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
The laptop will not turn on or boot, the power led will light but nothing further happens
Hello David,
Please remove the battery of laptop.
Press the power button for 15 minutes and it will discharge the capacitors of the laptop.
Repeat the step 4 to 5 times and then insert the battery and connect the charger.
Laptop will be boot up.
Apr 16, 2011 | Compaq Presario CQ70-116EM Laptop...
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Problem to switch on the cpu
Disconnect the UPS from your configuration,
and connect the AC power directly to a wall outlet.
Press the ON/OFF button and release it.
If nothing happens, press and hold the ON/OFF button for 10 seconds, until the computer turns itself completely off.
Then, press the ON/OFF button, to restart the computer.
Dec 08, 2009 | MSI K9MM-V Motherboard
Ihave hp laptop model#ze4200 it wont boot nothing happens on pressing the on/off button. only the a/c charging ledflashes for a while and turns off after few seconds
Besides a really serious failure, there are a few things to try...Remove the laptop battery, then hold the power button down for 10 seconds. Plug the AC adapter in, and leave the battery out. If the laptop starts up, you could just have a battery issue.
Nov 16, 2009 | HP Compaq Motherboard
Power button
hello
Follow the instructions.
  1. Take out the battery and the Ac power. Keep the power button pressed till all residue power is radiated.
  2. now connect the Ac power without the battery and try to start the system. Hope you have fixed the supply with proper soldering.
  3. if the system gets start then there is no problem with your system hardware is OK.
  4. now try battery. charge it fully and this will tell you if your battery is good.
  5. if it works with power supply but not with battery then there are two possibilities.
  • battery gone
  • charging module in the mother boad malfunctioning.
Thank you
Aug 16, 2009 | Computers & Internet
HP Compaq Business nx7010 Notebook Logo
222 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
