I have tried every thing but replacing s.c. card. How can I get music from my p.c.to g1
When you plug the phone into your pc using the USB cable an alert appears at the top of your phone notifying you of the USB connection. Slide the alert open and click on the "USB connected Select to copy files to/from your computer" alert. It gives you the option to mount the drive. Click on "Mount" - once you mount the drive. Open your file browser on your PC and the phone should be mounted as a flash drive. Click on the drive, you should be able to see all of the folders on your SD card including the folder containing your music.
T-Mobile is sending an over the air upgrade to all G1 phone to correct this problem. The only way it will work for now is to remove the memory card from your cell phone and insert it into an SD adpaptor and plug it into a memory card reader. It will sync.
Contact 611 from your cell phone and select G1 support for more details.
I have the same issue, my phone simply does not show up on the computer at all, even after clicking mount card.
