Question about HP LaserJet P2015dn Printer
Stopped printing and shows a job queue light.
It has stopped printing all of a sudden and shows a red light at the job queue sign which never switches off. it is located in a lab and about 20 Computers are connected to it and none can print. I cancelled all the jobs in all computers sent to that printer but still the printer cannot print and shows the red light.
Try disconnecting one of the computers
Posted on Jan 14, 2009
  • 32 Answers
Ben_ndee, if you press the "Go" button do you receive a secondary error light combination?
If this is the only combination you receive, the error is indicating a problem in the laser/scanner assembly.
Many times disconnecting and reconnecting the scanner will eliminate the error condition but there is a very good chance the laser/scanner assembly is faulty and needs to be replaced.
The part number is RM1-4262-000.
Posted on Nov 20, 2008
My printer is not printing
Without knowing any more, all I can do is take you through a tedious set of steps:
  1. Is it plugged in? Unplug the power cord at both ends, then plug it back in.
  2. Is it connected to your computer? Unplug the cord at both ends, then plug it back in.
  3. Is it turned on? Press the power button. Do any lights change (go on or off, change color, flash, etc.)?
  4. Send a print job to the printer. Does the printer show any signs of realizing it's been asked to print something (an indicator light or something moving inside)?
  5. Open the print queue. Delete all the jobs that are in there. Shut down the printer. Restart the computer. Turn the printer back on. Try printing.
  6. Are you getting error messages?
  7. What happened before it stopped working? Did you install new software? Move anything?
May 01, 2015 | HP DeskJet F380 All-In-One InkJet Printer
Has stopped printing has 3 jobs in queue
Hi There
HP often does this. You have to delete or cancel all the jobs in the queue, becausthe first job in the queue failed. Sometimes you gave to tell the computer many to cancel all jobs. Sometimes it is needed to restart your computer before the queue is empty. Only then will you be able to print again
Regards
Andre
Aug 29, 2011 | HP Office Equipment & Supplies
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
My printer will queue a job but will not print.
Hi hannahcath,
Please click on following link and download the software. which will help you out to resolve the issue,
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Jan 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
"JOBS STOPPED"
dear g-gal
Please reinstall the driver for the printer
Apr 07, 2008 | Epson RX620 All-In-One InkJet Photo...
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
HP LaserJet P2015dn Printer Logo
145 people viewed this question
Seeker5211
Seeker5211
