Question about Microsoft LifeCam VX-6000 Webcam
Mic problems when i try get my mic to work its like a ssshhhhhhhhhhhhhhhhhhhhhh loud noise...i dont know how to fix it i tried to adjust the volume but nothing helps
  • kristeeh Jan 25, 2009
    I get real echo of my voice and any movement near the web-cam mic when I use my web-cam and it is duplicated when use the "test hardware" under the Voice tab in Audio and Sound devices (Windows XP SP3).
    If I touch or move the cam the sound blasts us away.
    I have all other mics disconnected and checked mute on the microphone on master volume (this was for a mic that is not on USB.)
    khinton
    Sergeant:
    Champion:
  • 274 Answers
Go into the Control Panel and select Sound and Audio Devices.
Choose the tab Audio and then select under Sound Recording the Volume Button.
UNcheck any devices other than Microphone (checked). Also, put your microphone level midway.
See if that helps.
Posted on Nov 25, 2008
  • Ricky Ostrom
    Ricky Ostrom Nov 25, 2008
    Keep the mic away from the speakers, or you will get feedback.
Why is it suddenly way too quiet?
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Dec 18, 2015 | Samson C01U - USB Studio Condenser...
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Headphones with mic model # na
Hello...
Try this one:
1.Click on Start
2.navigate to Control Panel
3.click on Sound, Speech and Audio Device
4.click on Sounds and Audio devices
another window will appear
click on the Voice tab
on the Voice Recording
click on Volume
there should appear another window
adjust the Mic Volume
hope this helps
Oct 09, 2008 | Computers & Internet
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Microsoft VX-6000 audio problem - static noise coming from speakers
My webcam VX6000 picture is fine, but when i try to talk to anyone or do voice playback there is a loud echo and distortion both for me and the person i am trying to talk to. I have tried everything in support. I am running windows xp.
Dec 27, 2007 | Microsoft LifeCam VX-6000 Webcam
Microsoft LifeCam VX-6000 Webcam Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
