Whirlpool Washer will not progress to the rince cycle.
My Whirlpool washer will not move to the rinse cycle. It goes through the wash cycle and stops. It will not let out the water to refill with rinse water. I can turn the knob to the rinse cycle and it will do the agitation, but then stops again and will not spin out the water. Any suggestions?
  • Anonymous Mar 20, 2014
    Why won't my whirlpool washer run the rinse and spin cycles
  • Washing Mach... Master
  • 19,396 Answers
That is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    Whirlpool washer model lsr8233eqo
    So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
    Feb 03, 2013 | Whirlpool Washing Machines
    Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
    Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
    Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    Maytag ensignia makes a great deal of noise during rinse cycle
    "If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
    Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
    When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
    Hello
    Try reseting the machine.Unplug power for 60 seconds.
    Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
    It is possible the control timer is going bad.
    Aug 29, 2010 | GE Washing Machines
    The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
    you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
    Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
    LG washer won't move from the rinse cycle. Spins during the wash, but not in the rinse
    If you have correctly selected rince and it doesnt rince, that part of the program is corrupt. Strangely enough, in S.Africa 90% of the washers with rince problems are the lg. Seen quite a few top loaders with this problem as well. There is no reason at all that once rince is selected it shouldnt work, except if faulty.. Only solution is to replace board if rincing to you is essential.
    Sep 25, 2009 | LG WM-1832C Front Load Washer
    Flashing lights on Rince, Start & 0 speed.
    washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
    Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Washing Machines Logo
    1,022 people viewed this question
    Top Washing Machines Experts
