Question about Canon Laser Class 830i Plain Paper Fax
Doc feed problem on canon 830i
I HAVE A CUSTOMER WITH A CANON 830I FAX THAT IS HAVING SEPERATION PROBLEMS. I HAVE ALREADY CHANGED THE SEP PAD, PICKUP ROLLER & SEP ROLLER. WHAT AM I MISSING?
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: hi, i am getting a
Hi
1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
3. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
4. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
5. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
6. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
7. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 03, 2009
brett207
  • 231 Answers
SOURCE: Our RX report for our Canon 830i fax machine lists
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Posted on Dec 16, 2009
Testimonial: "Thank you!"
How to program TX report on a canon laser class 830i
You can find instruction on how to configure Transmission Reports on page 364 of the use guide. (see below)
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
Hope that helps.
Dec 19, 2014 | Canon Office Equipment & Supplies
How do I print the configuration page from the canon Laser class 830i fax machine
I am using a mac, and not the same brand printer, but I go to my system preferences, pick my printer, go to the top and pick "Options and Supplies" a new screen should open. There should be a "test" icon, as well as options for allignment, cleaning heads,etc..
Nov 19, 2014 | Canon Office Equipment & Supplies
I am getting a feeder glass dirty message. I have cleaned glass and rollers. Do I need to reset
look the cartridge is there some defect.and then do the reset.Its not anything big failure just the printer sometimes mix the right info.
Jun 05, 2014 | Canon Laser Class 830i Plain Paper Fax
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Photo copys are intermittently coming out black without copier settings being changed
you need to watch the exposure lamp under the glass . see if it goes out during a copy run. if so you may have a bad lamp, wires, invertor or pcb. if it does not go out you may need a drum, chagre replacemnet or developer. you may need a tech to look at it.
Oct 27, 2009 | Canon Laser Class 830i Plain Paper Fax
Red icon flashing on the display screen
It's the warning to replace teh back up battery housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
Red crossed horizontal icon flashes on screen
It's the warning to replace the backup battery which is housed behind the main battery.
Canon Laser Class 830i Plain Paper Fax Logo
53 people viewed this question
old marine
old marine
