Question about Logitech Z-640 Computer Speakers
There is no power
There in no power on the speaker when connectet to the outlet
  • ttaupea Nov 20, 2008
    there is no power
Check te switch wether its work...... or check your connection 15pin all the pins are in place if that okay its need to go into the main board
thanks
toki
Posted on Mar 26, 2009
I have a 220 watt amp with two speaker outlets. Mfg suggests I use a series Y for each of two speakers. Will that reduce overall power as compared to hooking each speaker from a different outlet
A Y/splitter cable with divide the power of that channel equally between the two speakers. Regardless of whether you use one speaker or two per connection point the total max audio output is still 220 watts. You're just distributing it between more speakers for better coverage.
Nov 11, 2014 | Car Audio & Video
I have the JBL speakers which are really decent but i want them to be as loud as possible! if i plugged in my logitech speakers into one of the inputs that i would normally put one of my little speakers in...
It should be OK BUT if the JBL and the Logitech are plugged into different mains outlets you could get a hum from one or both sets of speakers. This hum is caused by an earth loop when the speakers are connect to different mains outlets.
The fix.
Connect a power board to a mains outlet and then plug the mains connections from both set of speakers and computer to this power board.
Oct 25, 2012 | JBL Encounter 2.1 Computer Speakers
My speaker is making buzzzing sound?
You may have an earth loop problem.
This is caused by connecting your computer to a mains outlet and the powered speakers to a different mains outlet.
If this is the case then connect the computer and the speakers to a power board and then plug the power board to a mains outlet.
Jan 20, 2012 | Audio Players & Recorders
Midiland 8200 (ADS 4000 controller) 5.1 hum problem
You may have an earth loop problem. This is caused by connect various equipment to different mains power outlets.
Connect all the PCs, audio and speakers to a single mains power outlet, use a power board so they are connected to the one mains power outlet.
I suggest you use a power board that has a built-in surge protection.
Nov 14, 2011 | MidiLand S4 8200 Computer Speakers
Scx-f828fn system error cycle power
disconnect the printer from elektrik so there is no powercord connectet anny more for about 5 minutes, then connect it and try.
Apr 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
Hi! I have a problem with desktop speakers, buzzing sound without reproduction from sound card...other speakers work properly, so obviosly it is a problem with the speakers..the power suply is ok, diode is...
Are this powered speakers connect to the same mains power socket as the computer.
If not you may be getting an earth loop which causes a humming sound.
Connect these speakers to the same power outlet, if you have not sufficient outlets use a power board.
Apr 26, 2011 | Teac PowerMax 160 Desktop Speakers,...
How can i correct the front panel connections
your motherboard has three sockets for the front panel connection:
-USB socket, to connect any front usb ports you might have
-AUDIO socket, to connect speaker/microphone socket on the front of your case
-FRONTPANEL socket, where are connected the turn on/reset buttons, the ide/power leds and the buzzer. To connect all the pin in the right way, refer to the attached picturefranzer_2.jpg
Hope it helped,
Franz
Mar 02, 2011 | Gigabyte GA-8SMML Motherboard
Trying to find out why my desk speakers buzz when my monitor is on?
If the computer and the powered speakers are connected to different power outlets then you could have an earth loop. This causes a hum in the speakers, this also apply to hi-fi sound systems.
To fix this problem, connect all the computer components to a power board and plug it into a power outlet.
Nov 26, 2009 | Logitech X-530 Computer Speakers
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
How do i wire my audio bahn speakers to 2 or 1 ohm like i have them hooked up on 4 ohms but i wanna lower thew ohms there 2 other outlets on the speakers but how do i do it?
This is a 6 ohm speaker, which should be wired to a 6 ohm outlet, but 4 ohm outlet is working, so allow it to stay like that. If you try to connect to 2 or 1 ohm outlet, the performance will actually worsen. In electrical theory, maximum power is transferred to a load (speaker) when the impedance is a match. You already have a mis-match of 6 to 4 ohm, but it is close enough. Try not to go farther away from maximum power transfer. Your speaker will draw too much current on a 1 or 2 ohm outlet and you may end up blowing fuses, too.
Aug 06, 2007 | AudioBahn ALUM12 Car Subwoofer
Logitech Z-640 Computer Speakers Logo
135 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
