Question about Panasonic Lumix DMC-FX7 Digital Camera
Lens won't pop out! HELP!!!!!
The lens on my cam won't pop out! When I turn it on camera mode, a series of loud happens and my screen say,"PLEASE TURN CAMRA OFF AND THEN ON AGAIN." This is uber frustating. What do I do? How do I take this thing apart? Shoud I take it apart? Panasonic wants me to send it in to a service center. I'd rather know the problem and solution then send it in. PLEASE HELP!!!
    Novelist:
  • 198 Answers
Hello detroit73, This is a mechanical problem. The camera can't align the lents and proper focus or extend them them due to some sort of servomotor failure. Because of that, it tries to get a proper fix, but as it fails, it thinks that some object got the lents pushed or something like that and it askes you for a "reboot". You can't "hard boot" the camera, even a complete reset woun't help as this error is given by the camera's microcontroller circuitry (some sort of camera processor). The only fix can by given by an autorised service center. Even they may find out that you need the whole lens mechanism changed. This is because the lens assembly is a very delicate mechanism, including small coils, motors and the actual lens. If some of this components get loose, they can jamm or damage other parts, preventing the lens mechanism to extend.
Posted on Mar 31, 2007
SOURCE:
Dear Sir, I have SONY DSC W-55 series camera. Whenever I turn on the camera its lens tries to adjust and always displays a message for turning off and turn on again.
This is usually caused by impact damge to the lens barrel or sand/grit ingress.Quik turn on the camera let the lens try to adjust.Then remove the power with the lens extended as far as it will go. Hold the camera up and check if the front of the lens is exactly parallel with the camera housing. If it is skew you can try gently pulling on the inner barrel which(If your lucky) will pop back into the correct cam.
Mar 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera stuck in "lens error" mode
Hello, It's time to let a Nikon camera repairman take a look. If lens does not pop out, then it could be motor, shutter, etc, etc. Check out one of our Camera Repair providers and get a repair quote.
Nov 30, 2008 | Nikon Coolpix 4600 Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Sep 02, 2007 | Olympus MJU 400 Digital Camera
Cam prob
Have you tried absolutely fresh batteries of the correct type? If so Then it would seem that the lens mechanism is not fully functional. DO NOT TRY TO FORCE THIS - IT IS VERY FINE AND CAN BE WRECKED BY THE LIGHTEST TOUCH OF FORCE. Turn off the camera remove the battery and with the eraser on the end of a pencil polish the internal contacts in the base of the battery chamber. Do the same for the chamber lid. Hold the camera lens down and gently tap the side of the lens mount. Re assemble -see what happens. If still in trouble go to customer support on the makers website.
Jul 25, 2007 | Mercury Electronics CyberPix S-555V...
Switches off when try to take pics
i came to know the reason why this happens. the CCD is damaged. It will take around Rs2000 to repair the cam if you are in India.
Apr 18, 2007 | Fuji FinePix F401 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
105 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
