Question about Epson Lq300
Paper Size hi, i am working on Window OS. printing from a Java based application. I am using an Epson LQ 300 II Dot Matrix printer. We need to print on continuous paper which is 24cm wide & 14 cm in length, so about 1/2 A4 size. Anyway, what it's currently doing is printing the first invoice, then i moves down 13cm before it prints the next invoice. i've created a customer paper size on server properties with the sizes as specified about. I've set my application to use the printer setting as well. it worked for me last week where it was printing one invoice after the other after months of trying. the only change that i can remember making when it worked is to change it to tractor feed. i then changed the margins to be set to left & right 2.5cm, top & bottom 1cm in the custom print, now it leaves the gaps again. if there is anybody out there that can assist, please let me know. i've been working on this for 2 months now and still unsuccessful. it's only the one time it worked properly.i will try anything to make it work at this stage. if i need to change the drivers, please let me know.
5 Suggested Answers
Niteesh
  • 65 Answers
SOURCE: Epson LQ-1050 Matrix Printer Problem
1. spread som lubricant on printers rod, in which head moves.
2. change your data cable, or remove it & connect it properly.
Posted on Feb 23, 2008
  • 127 Answers
SOURCE: cant print continuosly in epson lq300+
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
Posted on Jul 08, 2009
MUKHTAR
  • 2022 Answers
SOURCE: LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Posted on Jan 12, 2010
onyekapaul
  • 122 Answers
SOURCE: Hi, One of our client using
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Posted on Mar 26, 2011
Lq 300+ii paper size setting
It works well with WINDOWS XP but how can i make it work with WINDOWS SERVER 2003
Jan 11, 2013 | Epson Dot Matrix LQ-300+II Printer
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
CANNOT INSTALL THE EPSON LQ 300+DOT MATRIX PRINTER ON THE WINDOWS 7 NEW PC
Epson LQ 300 does not have Win7 latest driver. Please use your old PC (xp or visita) to continue with the Epson.
Aug 28, 2011 | Epson Dot Matrix LQ-300+II Printer
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
My lq 2180 printer is not aligned properly.printing starts 2 to 3 inches from start of page.jump in every next page is increased by half inch.kindly guide Thanks
Dear user,
please check the paper size and the procedure is below.
open printer properties and then go to the printing preferences and then there slect there appropriate paper size according to your paper being used in printer.
hopefully it will work perfect.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson Lq300 Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
