Question about Sharp 55R-WP4H 55" Rear Projection Television
View timer is stuck on
My view timer has been stuck on and I am unable to receive a picture. I have unplugged the TV for hours at a time and even overnight and the TV set will not reset itself. When I turn on the TV it goes right to view timer mode and the red light is blinking. Does anyone have a solution to this problem I called Sharp and they were no help.
  • 2 more comments
  • Anonymous Dec 04, 2007
    my tv view finder is blinking and i can see anything the screen is not even on how do i reset the view timer
  • Anonymous Dec 14, 2007
    My view timer has been stuck on and I am unable to receive a picture I have unplugged the TV for hours at a time and even overnight and the TV set will not reset itself. When I turn on the TV it goes right to view timer mode and the red light is blinking.
  • Dave Roberts Dec 23, 2007
    I have exactly the same problem. I can unplug for days and when I turn the power back on, you hear "click, click, click..." then it goes to "view timer" and the light just flashes. While I appreciate the advice of "taking set to tech", this thing is the size of a buick so a house call is the only answer...you'd think there would be a "module" you could take out. Sharp? When their web site is working it's useless...this model is not even listed.
    Has anyone had this fixed?
    Genius:
  • 1,074 Answers
Take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Posted on Feb 25, 2007
SOURCE:
TVs On Timer light ia blinking and I cant get the
Go tothe tv manufacturer;s website -customer support and describe your dilema to them Give them the model number.. Many times all the tv set needs is a firmware upgrade. they can tell you about it.
Sep 03, 2014 | Televison & Video
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
My DISH Network DVR-625 DTV Receiver randomly freezes and resets itself and will only record 6-9 minutes of a program even though i have 50+ hours of available space. i've reset it several times. help?
ambrekulas,
I am sorry you are having problem with your picture freezing. You said you reset the receiver several times. Did you press the power on the receiver and release or did you unplug the receiver from the electrical outlet? Try unplugging it for about 10 seconds if you haven't already done so. If the problem persists, we'll need to replace the receiver. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 18, 2011 | DISH Network DVR-625 DTV Receiver /...
I have rear projection tv sharp 55u-wp7h. Unable to turn on tv due to view timer automatic turn on. what cause that and how to fix the problem?
I'm having same issue with same TV. It powers off after about an hour and red power light starts flashing. Only way to power back on is by unplugging TV and waiting a while, then plugging it back in, but then the TV will turn off again after a few more minutes, red light flashing again. I've checked the sleep timer and it is turned off, so any other solutions to this problem? All capacitors on power board look fine (not blown). I've read it could be solder joints in power board need to be resoldered.
Dec 17, 2010 | Sharp 55R-WP4H 55" Rear Projection...
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
DVR records blocks for 4-6 hours
If you have no manual timers with extended timers then replace the unit. That will eliminate the issue. Thanks for using Fix Ya.
Jul 03, 2009 | DISH Network DVR-625 DTV Receiver /...
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Will not turn off
It sounds like the contacts on the on-off relay are stuck on. You can tap the top of the relay cover and that will shut it off (releasing the contacts) For a permanent fix, try taking the plastic cover off the relay and clean the contacts with a file (or just replace the relay)
Aug 16, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Sharp 55R-WP4H 55" Rear Projection Television Logo
450 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
