Question about Panasonic VDR-M53 DVD Camcorder
Disc error My Panasonic mini dvd camcorder keeps giving me a message saying disc error and then when I try to record it keeps giving me the message to check disc, it may be cracked or insert properly I have tried everything please help it is less than a year old.
  • 1 more comment
  • Anonymous Dec 03, 2007
    I have cleaned the disk. Several times. Still no luck.
  • ryan10991 Feb 23, 2008
    i have the same problem. i've tried new discs, everything!
  • Lynn4597 Mar 18, 2008
    says disc error when attempting to record
Clean the disc
Posted on Apr 12, 2007
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Lost footage whilst trying to finalise a disc
problably not check disc in an other source , is this a disc brand you use before ?
Oct 31, 2009 | Panasonic VDR-D100 DVD Camcorder
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
May 15, 2009 | Sony Cameras
Disk Error
it could be something to do with th type of discs you are using or they could possibly need a clean.
Jan 11, 2009 | Samsung DVD Camcorder
Was recording fine then message to check disc when turned back on
Unless you've been unlucky and had two bad discs in a row its probably the camera. have you tried resetting the camera and trying again?
Jul 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Canon DC210 Camera
The error message is because, either
1. the disc was initialised on another camcorder, or maybe a PC, or
2. The disc has a recording on it in a different TV system (PAL v SECAM).
From the above, it may be you're using the same disc in two camcorders. To be sure of seeing what's on your disc you need to keep it with the same camcorder from 'initialise' to 'finalise' .
To be able to see the disc on a PC you need to finalise it on the camcorder. There's no other way to get to see your work on a PC.
Unfortunately I think you've lost your recordings this time.
Feb 08, 2008 | Canon DC210 DVD Camcorder
Panasonic VDR-M53 DVD Camcorder Logo
261 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
