Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 SLR 6MP 18-55 Lens
Hi can you please tell me if you can turn nikon d40 into a infrared camera thanks debss
    Scholar:
  • 83 Answers
Basic idea is to replace the infrared-cut filter in front of the CCD sensor with an infrared filter, so the camera only "sees" the light in/above near-infrared range (mostly invisible to human eye).
The operation on a d40 is a bit fiddly. You will of course need a replacement infrared filter. You can cut it yourself from a standard lens infrared filter (that's what I normally do). It might then need some positioning to get autofocus to work properly in case the replacement filter is not the same thickness as the original one.
I've actually just found this tutorial on the net, you might find it useful:
http://photocamel.com/forum/nikon-forum/58248-nikon-d40-infrared-conversion-tutorial.html
Good luck,
Raf
Posted on Nov 09, 2009
  • 23 Answers
I son't know how to turn a camera into an IR camera but I did find a website that shows you how to make a filter that allows you to take IR photos. You can make the filter yourself for free unless you don't have the items needed but then again the item needed are only a couple of dollars. Here is the link.
http://www.diyphotography.net/take_infrared_pictures_with_digital_camera_ir_filter
Posted on Dec 20, 2008
Please recommend digital SLR nikon cacmera for this lens
Any Nikon digital SLR will work with this lens. However, there are two things to consider.
On cameras other than the D700 and the D3 family, the smaller sensor will make the lens appear as a 105-315mm. On the D40, D40x, D60, D3000, D3100, and D5000 cameras, you will lose the autofocus capability.
Oct 18, 2010 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
Do the old AF lenses for the Nikon N60 SLR fit the new DSLR cameras
Hi ericm675, Yes they will. What you run into is were one uses a auto focus lens on a newer digital such as a D40. Some of the new digital cameras do not have the drive gear to turn the autofocus on the lens. Those newer cameras use electronics. Look on your camera lens mount at 7:00 you will see the drive pin. Look on your old autofocus lens you should see a slot where that pin fits. Hope this helps you.
Aug 22, 2010 | Nikon N60 35mm SLR Camera
Using a Nikon D40 digital slr with a AF-S DX Nikkor 18-200 1:3.5-5.6 G ED lens I was previously able to autofocus bun now am not. Can you suggest reasons why this may be?
Please check if the Autofocus-switch on your lens is set to M/A. Also check if the Autofocus on your camera is switched on. For detailed information about your cameras autofocus, please check this site: http://www.kenrockwell.com/nikon/d40/af-settings.htm
Jul 18, 2010 | Nikon D40x Digital Camera
Lens issues with Nikon D40 camera
Have you ever cleaned the contacts on the lens and the camera body where they meet? If not, do so now with a cotton swab lightly dampened with rubbing alcohol.
May 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Monitor blank when shooting picture. Viewfinder OK
while using slr cameras u always see in the viewfinder bcuz slr is a single lence refleime u can see the picture after shoot by clicking on play back option this is a feature of an slr camera
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
Nikon D40 camera will not work!
Did you try installing a battery, memory card, and turning it on? Oh, and dont forget to remove the lens cap.
May 19, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 LCD screen.
Since the camera is an SLR, (single lens reflex), the CCD image sensor is behind the shutter until you take a picture. Sorry, but you cannot use the LCD to take pictures.
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon lence
depends which lens you are using some Nikon lens does not work with D40
Dec 19, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
267 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
