Question about Zebra QL420 Thermal Printer
ZQL420+ is printeing an extra blank label with each good label.
Have a ZQl420 wireless in our whs. When we send print jobs via a queue on an Alpha Server, written in ZPL, the correct label printes then another on is generated each time. A wasteful blank one. Label prints fine when we used cable connected to teklogix term on same printer...no extra
Thanks.
  • Anonymous Mar 19, 2014
    Printer feeds a blank label after each good one.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Posted on Dec 11, 2008
What causes intermittent skipping of labels? In the middle of a print job the printer will spew a blank label then continue on with the print job, I'm hoping someone can help me with this issue.
Check your mailing list. Especially check how many invisible spaces are after a name or address. Suspect extra characters are pushing the mailing list into the next page or label and then it will print an extra blank page or label. Seen this happen when I was a Computer System Administrator and had to fix a similar fault for a client.
There is a reveal code option on most word processors that shows up hidden spaces.
May 27, 2015 | Office Equipment & Supplies
HP C7280 wont print custom size card stock 7.25 x10.25 wont feed or paper jam, however will print when fed on the left side but no guide to keep paper straight. how to correct this issue, Ive cleaned
Your question does not provide all the information necessary to absolutely resolve the issue. By now I suspect you've already resolved the issue or given up. Perhaps someone can use this info.
Need to know: Operating System (Windows 95/98/Vista/XP/7/8), Application (Word, Paint, Firefox, etc), type of job (jpg, pdf, text, etc.)
There is no short answer possible; but, I may be able to help with a generic answer. I can't help on Apple but I suspect it's the same as Windows, (and Unix, Linux, OS2, etc.).
Provided the Printer works proper on normal 8 ½ x 11 stock (print media) then it is not a printer or Queue issue unless it is just confused. As a printer technician I have seen this resolved by rebooting the machine(s) and trying to print again. If that doesn't resolve the issue you need to know:
The application you send the print job from tells the Queue what stock (letter, legal, card, envelope etc) to expect. The Queue, a component of all versions of Windows, is created when the printer is initially installed on the computer. The Queue holds print jobs and then sends them on to the printer when the printer tells the Queue it is ready. Some applications are more robust allowing more options than others. However, printing from inside a browser is frequently sketchy. If you're printing from an application that is different from the one that created it you may face an issue of the printer not getting the correct stock information.
Very Important: First before you attempt to send the print job check the settings in the app to insure your job has the right paper stock selected. Then, as you prepare to send the job from the app to the Queue before you hit the final "Print" button, check the "Paper Source/Size/Media" boxes in the "Printer Properties" to make sure your sending the right stock information. If that doesn't fix it; try to save your project in a format readable by another application and try to print it from the other app.
Note: 1. Print jobs are served to the printer by the Queue one at a time on a FIFO (First In First Out) basis. Sometimes print jobs get hung up in the Queue. A hung print job will block all subsequent jobs until the hung job is cleared. When a print job is sent and nothing happens (no printer activity or error messages on the screen.) look in the System Tray for a printer icon. Open it up and see if there are any jobs hung. If so cancel them and start afresh. This may require a reboot.
2. Print Queues can (rarely) become corrupt and must be deleted and rebuilt.
There are still variables too numerous to mention.
You can get HP Support at
HP Photosmart C7280 All in One Printer support
Whew! I've never tried to help resolve this issue in a post. Good Luck!
Dec 28, 2014 | HP Photosmart C7280 All-in-One Printer
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
HP 2015 Printer not printing as a shared printer
Hi Ronmur,
Few checks...
1. Is there sufficient diskspace for to queue print jobs?
2. There a corrupted print job that is holding the queue. Find the which application on which computer sent the print job. Send it again to see if it holds up the print queue.
Dec 15, 2008 | Office Equipment & Supplies
Extra blank page on ricoch printer
There could be a couple reasons...
  1. "Separator page" or "cover page" options could be enabled. The easiest way to find this option is to print a menu map from your machine. These are managed from the configuration page on the printer display
  2. Your printing from a terminal application, no fix...the terminal apps often send a (page break/ carriage return) at the end of jobs to make sure the page is printed and not held in queue.
  3. Check your settings in Office and print setup window - Word, Excel, etc. all have a "Seperator Page" and "Cover Page" options as well.
Hope this helps.
Jul 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Unable to send a print job to the device.
i know what your problem is phone 07764303923
Oct 06, 2007 | Canon imageRUNNER 5570 Copier
Zebra QL420  Thermal Printer Logo
1,496 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
