Question about Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain
Washer starts cycle. When ready to drain nd flashes. Went to board output test. when I push Presoak pump still does not drain I bypassed controls to turn pump on it drained fine.Is it an easy fix? or am i getting in to far.
  • 1 more comment
  • themanrlm Dec 03, 2007
    wont drain
  • Anonymous Dec 31, 2007
    washer will not drain
    is there a way to figure out the source of the problem
    or test the motor?
  • Anonymous Mar 26, 2009
    Had the same problem and found pieces of blue and white plastic like around top of washer tub in pump,after i removed them and put everything back together the washer works fine.
    Problem Solver:
  • 6 Answers
There was a obstructin in the motor fan blades i think there were 4 screws to remove to get 2 it, but it back together and it eas fine. I did how ever have to remove the the wire connector from the pump motor and reconnect to rerest the pump.
Thanks for the help
Posted on Jan 06, 2008
My washing machine did the same thing. Stopped at 11 minutes and would spin but not drain the water out. No money spent just time. I took the front panel off and back in the right hand corner is a drain that has 2 hose clips on. Take them off and look inside the white plastic part connecting this and inside you will proubly find money wedged up in their. I had several various change in their but the one was the 2 nickels that was lodged perfectly in their that would not allow the water to pump out. After I removed them and put it back works perfectly.
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
Tub filled with water, Lr code
To pump out the excess tub water while failing to complete spin cycle;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
If I could ask you to do a little troubleshooting;
It sounds like the wash/agitate cycle completes and you enter into the spin cycle of the selected wash cycle is that correct. When the wash cycle fails does the Cycle Status LED indicate that the washer is in the Spin cycle?
With a empty wash basket no wash load in the basket and you start a Spin Only cycle will the Spin Only cycle complete?
If the washer will start the cycle do you hear and loud Spin Only cycle noise such as metal against metal grinding noise?
With the washer off and no clothes in the wash basket can you open the lid then Spin the wash basket as fast as you can in the CCW direction the only direction. The wash basket should spin CCW several rotations and coast down to a smooth stop dose it?
I’m checking for Outer Tub increased bearing resistance…..Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi, I have a Neptune FAV6800 that I just got from a relative. He said it wouldn't complete the spin cycle. What I found is it started the wash cycle got to drain the first time and did drain but gave a nd...
Hey Jerry,
It’s a $1K machine and I feel fairly easy to work on…. But like most machines has its problems. Does the ND error code display after emptying the washer of water? If so I think you may have a stuck pressure switch.
Any other error codes?
Take a read thru this post
If you have a ND error code key into my trouble shooting comments of May 15, 2009
This forum member had clutch issues also that are comingled into the troubleshooting I don’t want to confuse you with your issue.
Here is the Service Manual for reference. Sears Parts Direct for reference.
You can pump out the excess Tub water with this process from the Service Manual;
Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Post back with an update and if you want to put on your DIY hat… let me know.
Good Luck Rich aka dh1200s
Nov 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader-will not start
Hello tinagomez479,
Some basic questions for troubleshooting;
Your machine type is a FVA6800AW/FAV9800AW correct?
Any errorcodes to the console?
Can you tell me what this action was for? “”We took it apart and cleaned it and put it back together and it worked good for about 5 loads then the water stopped draining and now it won't start again.”” Was this a Clutch clean up for dc/UC errors?
Does the clicking noise come from the console area like relays clicking or down below where the clutch pulley is located?
When you press the start button do the lid locks lock the lid?
Can you enter into Service Mode? If so can, can you turn on the drain pump for me? This will let us know if the Control Board is at least functioning in Service Mode and will take commands.
Go to page 16 of the Service Manual lower right hand part of page, Board Output Test and turn on the drain pump in service mode and see if the drain pump motor runs.
Here is the process; close the lid and enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test as the SM states with the off button or hit the Presoak key.
You mentioned it stopped draining, if the Control Board will take the command in Service Mode we can at least get rid of any standing water in the wash tub. When it stopped draining in the wash cycle did you take any error codes to the console like “ND”
Can you also try a Spin Only cycle and see if that will start and complete?
If you can’t do anything at the console pull the 120VAC power plug to the washer for 10 seconds then re-power up and try all above again.
Error codes are very helpful so please let me know what if any error codes you take to the console with your machine issue.
Rich
Jun 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag fav6800aww not draining
Are you taking an “ND” error to the display? Good job on checking for the clog from the sump cap to the input to the drain pump and out the drain pump to the drain pipe. The sump cap is sort of semi transparent if you shine a flash light on it do you see any restrictions? I had half of a bank card stuck in mine. This the sump cap item 9 of the parts view.
Drain Pump opened up;
I would try to turn on the drain pump in service mode and see if you hear it spin up. I guess the impeller could be jammed up. So let’s try that first. I post these links constantly for support so disregard if you have them. Link to Service Manual for reference. Sears Parts Direct for reference.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode and see if the motor runs. Here is the test; close the lid and enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test as the SM states with off button or hit the Presoak key. If the drain pumps sounds like it turns on I would put in a bucket of water in the wash basket and see how the output stream looks out of the drain hose when you turn on the Drain Pump in service mode. I get about a 2.5" vertical lift of the output stream from the drain pump.
Post back for questions or any help we can provide. Rich
Jun 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Code nd FAV6800AWW, Serial number 10
Hello HopelessR,
Don’t buy a clutch I don’t feel it’s a clutch issue at this point. I hope you can hang in there for some basic troubleshooting. I’m an owner like you not a repair person but I have worked some issues. I feel with the info supplied that you have a true “nd” alarm. The “nd” alarm is triggered when the washer fails to drain completely as monitored by the pressure switch input to the control board and the factory program time limit required for draining the washer. I have never experienced an “nd” alarm until this evening. This was a user induced “nd” failure by pumping wash water back into the tub during the drain cycle of Quick Wash cycle. I started a Quick Wash cycle with no clothes in the washer and with the remaining three settings set to min settings. At the 22 min mark the washer started the drain pump and began a slow spin CCW of the wash basket. It took several minutes of pumping wash water back into the wash tub to trigger “nd” alarm. The washer indicated time stayed at the 21 min mark until the “nd” alarm triggered. 1st test; could you start a Quick Wash cycle with what you would consider a full wash load with the settings I mentioned and let’s see what the results are. I don’t feel you have a clutch issue with no dc/UC error codes to the console. I believe at this point that you have a drain restriction problem. I can’t explain why the washer completes the cycle with the wash basket empty at this point. The 2nd test, do you have a deep sink you can pump the wash water into and observe the stream output? The stream my FAV6800AWW will produce is about a 3” vertical column of water out of the drain pipe held over the deep sink with the drain pump running and no clothes in the wash basket. If you have a deep sink and a helper that can turn on the drain pump in service mode as outlined below we can compare your drain pump output to mine.
You can turn on the drain pump in Service Mode with the process below.
1. Enter Service Mode by pressing both the Enviro Plus and Spin Only keys simultaneously until the washer beeps.
2. Next you need to go into the Board Output Test by pressing the Delicates key; your display should now read “ot”.
3. Now press the Presoak key this will start the drain pump and it should begin to empty the tub.
You can press the Off button to stop the drain pump.
If the output stream is low we can troubleshoot the restriction starting at the Sump Cap Item 9 and work back toward the drain pump.
I’ll hang in there with you if you want to continue to troubleshoot the issue. Maybe we can get some suggestions from other forum members. Rich
The Service Manual for reference. Sears Parts Direct for reference.
May 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
212 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
