Question about Refrigerators
Refrigerator/Freezer Whirlpool ED25TE stops working
I just got a used Whirlpool ED25TE. Worked fine for a couple of days, then I found that it had stopped working and everything got defrosted (the refrigerator section was not being cooled either). I unplugged it and plugged back in a few minuted, and set the dial to off and the to medium and it started. It worked fine for 3-4 more days, and then the same thing happened. I repeated my solution from last time, and it works again . . . for how long I don't know. Can you tell me how I can fix this problem please?
  • 2 more comments
  • danielmorar Dec 06, 2008
    Me again. I ended up changing out the defrost timer and the thermostat and it is working great!
  • Anonymous Dec 15, 2008
    our ed25te recently stopped getting cold on both sides.I am looking for a way to determine the cause.I'm not sure if it is the compressor or something else and don't want to find out the hard way
  • Anonymous Jan 05, 2009
    I purchased my WP - Model ED25te in 2000 and has just in the last 24hours done the same thing.
  • Anonymous Feb 03, 2009
    I have the same problem. When I turn the controls off and then on again I can hear the compressor start up again. Something is failing to begin cooling when the temp rises. some type of thermastat perhaps?
  • 1,830 Answers
I suggest to call a Whirlpool repairman.
Posted on May 19, 2017
    Habit-Forming:
    New Friend:
  • 117 Answers
Check to see if the Finn type coil next to compressor is dirty and clean it out with a brush or vacuum
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
appldoctom
  • 311 Answers
SOURCE: refrigerator is not defrosting right..whirlpool ref..
is it frost or ice.if frost you will need an ohm meter to check continouty on the heaters and term thermostat.term thermo must be cold to check.if ther ok check voltage to the heater system from the defrost timer.if no voltage replace timer.if its ice it could be a blocked defrost drain.unblock clean out
Posted on Dec 31, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
  • 7 Answers
SOURCE: The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Posted on Mar 25, 2010
Fridge boken, freezer fine
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 01, 2010 | GE GSS25IFR Side by Side Refrigerator
Fridge stops running after about a day.
That is a faulty defrost system.
Test the defrost thermostat, heating coil and fan, and replace the faulty part.
the defrost system is located behind freezer firewall.
Regards.
Sep 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 03, 2017 | Whirlpool Freezers
Freezer froze up, refrigerator compartment warm after hooking up
look in the freezer and see if there is frost on the back wall if so take back panel off and checked defrost t-stat on top of the coil leave it in the ice and cut the wires and ohm it out if there is no ohms it is bad if it is good check the heater
Jan 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
1,166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
