Question about NEC VT47 Multimedia Projector
Projection is upside down. Need instructions on how to correct problem
    Problem Solver:
  • 5 Answers
If this is the VT47 then press menu, scroll down to setup, orientation and then select the one you need!
Posted on Dec 10, 2008
Time is projected upside down on ceiling, can that be corrected
Here is the link to the manual. There is, on page 3, instructions on how to rotate the projected display. A button will move it 90 degrees at at time. Twice should do the trick.....
Dec 10, 2015 | La Crosse Technology LaCrosse Technology...
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
I made the screen go upside down how do I change it back
okay 1st of all you need to take it off its mount if you havent done so yet or if you never did, you need to connect it to its power cord, press power put it upside down focusing it first of corse, press menu, setup/ installation whatever your projector calls it, projection,and select the correct one, when it has gone back to normall, put unit correct way up and enjoy.
Jan 21, 2010 | Office Equipment & Supplies
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Manual
You don't need a manual.
Upside down view through the telescope is normal. The scope is primarily for astronomical use and the concept of "up and down" is null in space.
If you want to use it for terrestrial viewing, you'll need an erecting eyepiece witch will correct up and down and left and right.
Apr 14, 2008 | Optics
Picture projected upside down
1-press menu button 2- press down arrow and go to setting and press enter3-go to screen and press enter.4-go to projection and press enter. select front and press enter.
Dec 15, 2007 | Epson EMP-74L Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
NEC VT47 Multimedia Projector Logo
134 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
