Question about Sony PlayStation 2 (PS2) Console
How can I hook up the Playstation 2 to my DirectTV Cable box?
I have called DirectTV 2 times asking for Tech Support and keep asking this same question as to how to connect the Playstation 2 gaming system to my DirectTV cable box?
DirectTV says they only have Customer Service and that they can answer my questions, however I have tried their methods and it still does not work? So far my 13 year old is sad as she cannot play her gaming system.
Thanks for your time
  • 3 more comments
  • Anonymous Dec 06, 2008
    Let me know if youget an answer as I just did the same thing--ahhhh---
  • Anonymous Dec 14, 2008
    i cant get the thing to work
  • Ryount19 Dec 30, 2008
    I have same problem with PS2
    D
  • Anonymous Feb 15, 2009
    how do u hook ur ps2 to a direct tv cable box
  • Anonymous Feb 18, 2009
    Can't get it to work
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
I need to know what box you have.I have two options in my manual.
Here are the model numbers GAEB0A ,,,,,,,,next one GCEB0A
i just need to know witch one you have
Posted on Nov 21, 2008
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
No signal -Samsung HC-R4755
Well Dave have a tech come out and solder your ANT1 connection back on its a simple job that will probably set you back $50.00 or less.
May 31, 2010 | Samsung HC-R4755W 47" HDTV
Connecting internet to the playstation 3
Before connecting the ethernet cable to the back of your Playstaion3 hold the modem reset button for 15 seconds, when 15 secs are up connect the ethernet cable to your ps3 system, wait until tour Comcast High Speed Internet goes online again (all the lights are showing fine) then try setting up your Playstation connection settings again, it might work since now you have reseted your modem and the modem will send information to new device, I hope this information works for you, :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
I have direct tv hooked into my ant/cable hookup I get no channel
pull the card out of the front of the directtv box ...wait 1 minute and put back in...turn box on...hope this helps
Jan 03, 2010 | Televison & Video
I have a Sylvania TV that does not have a separate audio in/out connection. It only has 2 composite wire connections one on either side of the TV...I have a Sony DAV-BC150 5.1 surround system and a...
Maybe I don't quite get what you're trying to do.
Unless you still tune programs off the air from the TV tuner and an antenna - what possible TV program would come into the TV that the DirectTV box wouldn't already provide high quality sound and video for? You should run the audio from the DirectTV box to the receiver.
May 04, 2009 | Sony DAV-BC150 System
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Playstation 2
You shouldn't need to connect your PS2 to your cable box. Both are video signal sources.
However, some cable boxes do have aux or line inputs. In that case you would connect the yellow, red and white plugs from the PS2 AV cable to your cable box's yellow, red and white inputs. Make sure the jacks you plug in to are labelled input or in, otherwise they're outputs and they won't work.
Apr 07, 2008 | Sony PlayStation 2 (PS2) Console
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Sony PlayStation 2 (PS2) Console Logo
862 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
