Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 External Hard Drive
Hard drive shows as visible in My Computer, and when i right clieck i can see the amount of data that exists on it, but when you double clieck on it there is just a wordpad doc thats called 'version', and no way to access the files.
Any ideas?
Thanks
  • sayrewhite Nov 27, 2008
    my maxtor personal storage 3200 is recognised but windows says the disc is "corrupted and unreadable" . is there any way to fix this? my virus scanners can't access the disc...
  • 189 Answers
That happens when your computer was infected by virus, have it scan, it will be good if you can use different scanner aside from what is installed in your computer.
Thanks
Posted on Nov 20, 2008
External maxtor isn't recognized on XP
Since you have important files on this drive, do not waste a lot of time with troubleshooting. If your drive is about to go out, you can put it over the edge that way and kill it.
Just to be sure, I would plug the drive into 1 other computer just to make sure. If you get the same thing, the problem is definently with the Hard Drive.
If this is the situation, I would take off the outer case to reveal the regular hard drive inside. You can hook this hard drive up to your computer as a slave and copy the files off. If your computer will not read the drive as a slave, and you have double checked the jumper settings and cable position.....you can try a program like "Get Data Back" to try and recover data off the bad/corrupted hard drive.
Jun 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Jun 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 personal 200gb drive external
If you did in fact change the partioning structure then the only recourse is to send the drive to a data recovery center. If the drive is running they should be able to recover the data.
Apr 07, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor storage 3200
right click my computer
select manage
select disk managment
right click on the maxtor drive then select change drive leter to "L" if you like.
Apr 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
41 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
