Question about Mitsubishi WS-55511 55" Rear Projection Television
Need the location to the reset button on the mitsubishi vs 7085
Can you help me with this problem the set was on and working fine then we removed the protective sheet on the screen due to static the picture went out but we had sound turned off the unit thinking it would reset but now the power doesnt work i do here a couple of clicks when i plug it in tryed unplugging it overnight but still wont work i need to locate the reset button if one exists
The reset button should be a tiny hole in the front near the power button. You'll need to insert a small pointed object such as a toothpick in to press it. You'll see the familiar blinking light then it will turn off and you should be all set.
Posted on Nov 24, 2008
I have a Mitsubishi VS-7085 TV 3 Bulb projection, the tv was on working fine then the picture went out but we could still hear the sound and change channels what can I do?
look to see if the three tubes are lit or not, also see if picture on any input or just retire the set as somewhat old.
Nov 27, 2012 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
I HAVE A MITSUBISHI VS 7085 TV NOT POWERING UP AND WHERN PLUG ON HAERING A CLICK SOUND
if ya ever found out the cause of this please email me as i am going through the same thing with the exact same model my email is peoriaguy73@yahoo.com
Feb 19, 2010 | Mitsubishi VS-7085 70" Rear Projection...
Is there a reset? VS-60803
menu -1-3-7-0
then inital
then enter
DO NOT DO THE E2 RESET!!!!
Let me know if you need more help
Tim nolan
Sep 17, 2008 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
I have a Mitsubishi MDT4025 it goes on but i'm not getting a picture
What can I do to get this fix without taking it to the repaire shop?
Dec 01, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Mitsubishi Model # VS-7085
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Sep 05, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
