Question about Dell 5650 Computer Speakers
No sound coming from the rear speakers
I am haveing no sound coming from my rear left and right speakers at all. I have unpluged them and repluged the cords in. I have even played around with the settings on the comuter to have no help come from this either. Could you please help me and give me a few suggestions on what could be going on here. Thanks!!!!
  • 2 more comments
  • GlenH Jan 22, 2008
    Fantastic! Solved the problem for me.
  • Anonymous Feb 18, 2008
    I have a Dell computer but since I bought no sound has ever come from its in built speakers
  • Anonymous May 08, 2008
    The two back speakers and the one with the volume control dpon't work.
    Only the front (two) speakers work.
    Mike B
  • krassanai May 08, 2008
    Rear left and right speakers don't work.
I had the exact same problem and could not for the life of me figure it out. I literally just figured it out now, over two years later. If you plug your speakers into your computer using each separate plug (black, green, and yellow), use the adapter that should have come with the speakers set. I'm sure if you've had it long enough you may have lost it by now but luckily my pack-rat ways saved the day for me. Use the adapter so that you only need to plug into the green input and they work perfectly now. If that doesn't solve your problem... well I guess you're outta luck with me.
Posted on Nov 21, 2007
    New Friend:
I have the same problem. Only one of my rear speaker isn't working.. I think i have this adapter if it is the thing with three wires than on output is only one.
Posted on Dec 15, 2012
  • oltianvllahi
    oltianvllahi Dec 15, 2012
Great work, devmeister, and thanks so much! I had the problem for 3 years but luckily still had the adaptor in my "what the hell is this" bin? This may be the only time I've gotten something useful out of that bin!
Posted on Nov 08, 2008
I too had my adaptor, I tried your solutioon and it worked, fantastic thanks blindbatty.
krassanai
Posted on May 08, 2008
    Devmeister,
    Your solution worked for me too, thank you.
    Krassanai & Mike B (same person)
Devmeister.
I had the same problem for the longest time. I jusy decieded to figure this out. After surfing the web for a few minutes I found your solution. Like you I still had my adapter. The sound is once again awsome. THanx
Posted on Jan 06, 2008
  • 84 Answers
Make sure that if your speakers have a front/rear balance that it is centered.
Posted on Jun 20, 2007
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
YAMAHA HTR-6030 AV Receiver. Right and left front speakers have ceased to produce any sound
Unplug and replug the wires and check for damages as well, set audio settings on the device if its matching settings on receiver as well, try testing the settings thru TEST TONE CHECK
MANUAL
Apr 29, 2008 | Audio Players & Recorders
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
My door speakers wont play but my box does
Hello
Check the speakers first. Then check the wiring. There are Front Right, Front Left, Rear Right, Rear left speakers and supply, antenna, etc are connected by one pin to a socket. Check this pin&socket for rigid connection. Unplug and replug it two or more times, so that if there is any loose contacts with this socket and pin connections will be rectified. If this does not help you, check the internal connection of this socket, This is actually a skilled work, you have to open your player. The fault is surely with this socket and pin connections itself. Work out with concentration. Check the door speakers first before doint anything further. If you fail to detect the fault, let it retified by any auto-electrician. No internal circuit fault to this set is there. OK.
Sep 03, 2011 | Kenwood KDC-519 CD Player
I installed a new Sony CD player in my 1996 Toyota Forerunner and the speakers won't work. The player has power but there is no sound. I did not use a wiring harness but I did have the wiring diagram for...
Be sure that the wires are connected correctly. If no sound comes out could be speakers are bad, but highly unlikely that all four would be. Could be the stereo amplifier is out. You could try using an amplifier to connect the speakers. One other option run new wire to each speaker to make sure wiring is still good. Constant 12V+ Blue/Yellow or Blue/Black Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Rear Doors Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
Feb 14, 2011 | Car Audio & Video
Left headphone speaker and left speaker both are not working.
Probably, unless there is another setting that you have missed. Have you loaded the correct drivers for the sound card?
Jun 03, 2009 | Microsoft Windows XP Professional SP2
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Yamaha HTR-6030, Sound only from Front Speakers
u could have it cross wired some systems wire in sequence not always pos and neg
Aug 23, 2008 | Yamaha HTR-6030 Receiver
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
One speaker not working.
Suggest you swap the right speaker into the left output if it works the the amplifer in the control unit is faulty. IF still on sound then the rigth speaker is faulty.
Oct 03, 2006 | Harman Kardon SoundSticks II Computer...
Dell 5650 Computer Speakers Logo
248 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Vernon Taylor
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
