Question about Braun Syncro 7526 Electric Shaver
How to replace battery on braun 7526 electric shaver
All I can find is a replacement PC board with new battery - that would be OK, but I do not understand how to OPEN the shaver.
  • Sakina10a Jan 13, 2009
    This is helpful, but a little more detail on each step would have helped for those of us that are not very mechanical.
    Problem Solver:
  • 5 Answers
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
2 Suggested Answers
brector3
  • 1585 Answers
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Nov 28, 2010
Where can I purchase the circuit board and batteries in Johannesburg
Braun no longer supplies this type of replacement part for any of their shavers. Unfortunately, they are no longer available.
Mar 26, 2014 | Braun Syncro 7526 Electric Shaver
Braun 7526 requires new battery
You will find the correct battery type at shaveroutlet.com at the link below. You will need two. Scroll down the page for video instructions
Sep 02, 2011 | Braun Syncro 7526 Electric Shaver
My Braun 7526 shaver will no longer hold a charge. Should I just replace the batteries, or should I replace the whole power unit?
If the unit still works but just doesn't hold a charge well, you can just change the batteries. It is much less expensive to do this. You will find compatible batteries at shaveroutlet.com. You will need two. See link below. Scroll down the page for helpful video instructions
The PC board for your model has been discontinued by the manufacturer. You may be able to find a store on-line that still has some old stock on hand if you prefer to change the whole board
Jul 27, 2011 | Braun Syncro 7526 Electric Shaver
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
Need to replace the battery on a Braun 7526 shaver?
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
Scroll don the page for installation tip and video showing how to disassemble the shaver
Feb 28, 2011 | Braun Syncro 7526 Electric Shaver
Braun 7526 needs new rechargable battery
You will find batteries for model 7526 at shaveroutlet.com. See link below
Scroll down the page for disassembly video instructions.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Braun Syncro 7526 Electric Shaver
Need new batteries for 7526 braun
You will find compatible batteries at shaveroutlet.com. See link below.
I suggest that you read the installation tip on the page
Nov 24, 2010 | Braun Syncro 7526 Electric Shaver
I have a Braun model 7526 shaver and the batteries need to be replaced. I just ordered them and they come together on the circuit board. I'd like instructions on how to open the shaver's case and replace...
You will need to first remove the 'cap' on the bottom of the shaver. This is a piece of plastic that surround the hole on the bottom of the shaver where the cord plugs in. Gently pry it off with a small flat screwdriver or similar object. Once removed, the side grips will simply pull off revealing 4 screws on the back. Remove screws to remove the back cover.
From there it is a piece of cake. The internal components simply lift out.
Put it back together in reverse order
Jan 20, 2010 | Braun Syncro 7526 Electric Shaver
Braun 7526 battery problem
Open the shaver:
4) Open shaver
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
6,316 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
hvend
Level 1 Expert
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
